RST clocks
RST clocks
Hi guys, i went to fit some rst clocks into the bonus today thinking the connections were the same but turns out there completely different? Is there anyway around this without rewiring?
Cheers Daryl
Cheers Daryl
going sideways in a fwd
buy the plugs for the correct dash there are 2 types of mk4 xr3i rs turbo clocks
fuel on left or temp guage on left
colour match most wires and add at least 1 from coil for rev counter
It's not just a matter of the fuel left/right they are completely different.
What I did with my brothers Orion was take a pair of connectors off a scrap XR3i/RS Turbo loom, then wire them in parallel with the old connectors. All the wires are the same colours, but you have to add a rev counter wire.
Lee
I guess you misinterpreted it. Base model clocks (I.e. Without a rev counter) have diferent plugs to both the higher spec clocks. Both the higher spec clocks (fuel left or right) have the same plugs, the pinouts are diferent.
My reply offered an alternative method for connectivity. Plus, you didn't even answer the questions and your grammar leaves a lot to be desired...
Lee
07-10-2015 12:56 PM
Mr S1
20
27-09-2015 04:06 PM
