bailey oil breather
bailey oil breather
what are the benefits of having these I know they are to separate the oil and vapour but on all the ones I have there has been oil in the metering head so I run to atmos so what difference is there by running a bailey to atmos as opposed to the standard setup to atmos
The CVH is a very heavy breathing engine. As you up the boost, the crankcase pressure tends to increase and ends up blowing the oil cap off or the dipstick out. Not ideal.
An aftermarket breather allows you to safely increase boost without worry of high crankcase pressures.
I personally opted for a spec-r breather as it has a smaller footprint:
Lee
Lee
I know what they are for but would like to know what the difference is between having one and running it to atmos because it not really much different from say just using a hose and normal breather
I originally intended to run just a filter off the rocker cover. This just drips oil everywhere and for EFi you need a breather takeoff for the idle.
Like I say, there's nothing wrong with the original system until you run in to breathing issues. The aftermarket breathers give you the option of venting to atmosphere without any of the oily mess of just a filter on the rocker cover.
Lee
