standard cam replacement
Old 09-08-2014, 06:01 AM
tlr_rst
tlr_rst's Avatar
Default standard cam replacement
with a high mileage 177k, no performance upgrades just a standard car with s/s exhaust, think the rattling at high revs 4-6krpm is to do with the cam lifters, followers have no idea about cams, what lifters are, what followers are and tappets are so please advise what i should replace this hydraulic cam with.
Not after super performance or anything, just the standard hydraulic alternative.
And can i do it myself?
Old 09-08-2014, 07:09 AM
mentalasanything
mentalasanything's Avatar
Hello mate,
Tappets, lifters and followers are all words to describe the same part: the hydraulic component that operates the rocker arm as the cam rotates.
With a car as standard as that I'd stick with a high quality standard replacement.
Changing it yourself depends on how handy you are with a spanner? A basic socket set and a torque wrench are all you need, and it can be done with the engine in the car without too much hassle.
Lee
Old 09-08-2014, 08:26 AM
tlr_rst
tlr_rst's Avatar
Hello Lee
thank you for replying and clearing some of that up, I'm quite handy with a socket set, and drivers, had interior out and replaced most gaskets myself apart from a head one. Im sure i can attempt it myself, it would bring great satisfaction of doing it myself.
Just which high quality standard replacement do i go with. Ford don't supply the hydraulic cam anymore. Everyone talks about solid cams. I hear all sorts kent, piper, newman but all are for modded engines and fast road spec.
Old 09-08-2014, 12:39 PM
mentalasanything
Absolutely, for a mild form of tune, the standard cam with hydraulic tappets are the way to go.
I'd go to your local motor factors, ask them what they have or can get and what the warranties are. Don't forget to buy rocker nuts too if they're not in the kit as they're stretch nuts!
I forget what brand I have in mine but it's a standard cam with hydraulic tappets.
Lee
Old 09-08-2014, 07:29 PM
mattxr3i
mattxr3i's Avatar
Hi, I also would like to know a good brand for Cams. I currently have an Ultra Parts cam and I am not impressed... FAI any good?
Old 14-08-2014, 12:41 PM
Karlos G
Balls Deep!
Karlos G's Avatar
They are all equally risky IME these days, low demand for CVH cams has left them being made by the lowest bidder in the far east... the chocolate quality reflects this.
Even in your engine mate I would still go with a Newman cam kit just so you don't destroy what's left of that moon mile engine! lol If you then decided to refresh the bottom end at some point (if it starts knocking or smoking) you already have a nice cam up top.
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
SmudgerByName
52
28-07-2016 06:14 PM
bigryrs
28-03-2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
21-01-2016 09:54 PM
martsmotor
Ford Focus Range
27-08-2015 08:08 PM
Quick Reply: standard cam replacement
