Cosworth management s2 no spark no fuel pump priming?
Old 16-07-2014, 03:38 PM
saman
saman's Avatar
Default Cosworth management s2 no spark no fuel pump priming?
Hi ppl i need help i was driving my rs turbo with cosworth mangement and it cut out on me. Iv checked for spark ther is none and the fuel pump is not priming.
The the two yellow relay one of them is clicking wen i turn ignition on and the other yellow relay does not click any help plz need help before ford fair thanks:
Old 16-07-2014, 03:54 PM
jon@work
jon@work's Avatar
check your crank sensor
Old 16-07-2014, 05:43 PM
saman
saman's Avatar
iv got fuel pump working but no spark?
Old 16-07-2014, 06:04 PM
studabear
studabear's Avatar
Are the injectors pulsing?
Old 16-07-2014, 06:12 PM
saman
saman's Avatar
yes injectors r pulsing
Old 16-07-2014, 06:23 PM
darrenb16two
darrenb16two's Avatar
Both relays need to click when you turn the ignition on mate
studabear
studabear's Avatar
are you on coil pack or dizzy?
Old 16-07-2014, 06:27 PM
saman
saman's Avatar
both relays r clickin now
saman
saman's Avatar
still no spark
Old 16-07-2014, 06:47 PM
saman
saman's Avatar
im on dizzy
Old 16-07-2014, 07:02 PM
studabear
studabear's Avatar
have you checked the basics like the carbon bush in the dizzy cap, after that I think you will need to check wiring to coil and ignition amp to find out the issue
Old 21-07-2014, 07:30 AM
Gadget
Spanner monkey
Gadget's Avatar
if the fuel pump is running when cranking, that should rule out the crank sensor, but if it's just priming on the ignition, that'll be the relay pulsing it.
Usually no spark and no pump running would be the crank sensor
Old 21-07-2014, 08:32 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
Dude stop messing about with it. Letting everyone get thier fingures on her is just pimping her out like a cheap slut.
Its a minor whatever, as the car is an animal when running.
Ill see ya this week.
Old 16-09-2014, 02:34 PM
saman
saman's Avatar
The car is running now it was the ingnition amp but now got another problem the car does idle around 1500 rpm and wont rev and when I do rev with pedal to floor its popping and banging? Took the plugs out thinkin they would be wet but ok ? Help plz cheers
Old 16-09-2014, 08:59 PM
studabear
studabear's Avatar
What has Jano suggested?
High revs could be a air leak, have a look at your map sensor pipework,
Old 16-09-2014, 09:02 PM
saman
saman's Avatar
Its revs r at 1500rpm on idle but wen I press the throttle its not revving up its popping and banging
Old 16-09-2014, 09:03 PM
saman
saman's Avatar
Iv tryed swapping a map sensor off my mates car still the same
Old 17-09-2014, 02:36 PM
darrenb16two
TPS set right?
Old 17-09-2014, 02:39 PM
saman
saman's Avatar
It was set up by jano. How is the tps set?
Old 12-12-2014, 05:23 PM
Fezzrs
Fezzrs's Avatar
Hi mate check the gap on the crank and phase sensor tgey have to be so close 0.2 mm to get a spark it coukd of knocked out of position
As for tge relay not clicking take both relays out clean contacts plug back in or replace for new ones chevk wiring on both as well clean with sandpaper
Map sensor chevk the voltage and air sensor common for failing
Old 12-12-2014, 05:25 PM
Fezzrs
Fezzrs's Avatar
Also chevk the plug on the ignition amp replace if corroded terminals
Leads and plugs changed recently ? Everything ive said i bet your problem lies in there
Old 12-12-2014, 06:54 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Change management to something more reliable is my advice, so many threads about Cossie management not running right these days, it's old, the looms are old, dizzy, amp, MAP, etc. all old, same goes for Fiesta RST/XR3i/XR2i EFI.... can spend so much time and money trying to chase down problems it's just not worth it IMO, more and more people are binning it off for something new.
I know Jano won't agree but that's just my opinion/experience lol
Old 14-12-2014, 11:14 AM
Versus_Creations
Ask me a question!
You talk so much crap karlos I have had enough of people sending me links of you spreading bull shit to the masses.
We both know all sensors are available. As is loom or any other part.
If you have the money buy new sensors and you wont have issues.
The management is just as reliable as the next system. Why wouldnt it be.
If you dont know your way around an engine, then why mess around with it and blame things you dont actually know about.
Over the last 15 years how many management systems do think I have fitted. i can tell you now that everyone of them are in a better value for money position than you could offer with what ever gimik you can supply.
If the op came over id sort it out within minutes I know what it is to cause the idle to stick at 1500., (not advertising just explaining) its his choice he would rather ask on here and get loads of random answers and misguided help.
If he went to the correct website he would of got all the help he needed anyway.
so stop with the propaganda as we both know you cant beat the value for money the weber system offers. If you could I would quite happily supply this system over my choice.
You make out like I dont use anything else. The fact is I make less money by selling weber than I would from selling any other system. Last month I sold more life racing amd pectel ecus than anything else. For example I would make almost 230 quid just by selling a new after market ecu like omex or emrald etc etc. I choose not to and fit weber instead value for money for the customer. If I was a total dick like some I would just take the higher profit margin and newer system.
So think a little why I choose weber. If there was a better way I woild use it on my own cars!!!
all I see you do is knock things you dont like or cant make money from. The difference is I will knock things because there is no value for money reason to use it. Not to make money from it. My customers prove the fact that caring about their pocket is more important than just getting the job
Obviously your lacking experiance then by your own admittance. We all know you have an opinion haha.
Old 14-12-2014, 11:33 AM
Fezzrs
Fezzrs's Avatar
Thats why i went for cossie managent better sensors throttke body etc omex woukd cost a bomb and you still need stuff to make it work
Old 14-12-2014, 11:46 AM
studabear
studabear's Avatar
Whatever management you fit will need throttle body/sensors etc.
Standalone management can be calibrated/set up for pretty much any sensors you choose.
Old 14-12-2014, 12:20 PM
Versus_Creations
Ask me a question!
...... the best sensors to use are.......
the same as whats fitted to a standard cossie.
So lets fit a new management costing loads more.
Use the same sensors either second hand or new.
Get the same results as the next person who spent half the amount
Then go round telling people they are better off.
You dont need to, or have to experience much to understand value for money.
Old 14-12-2014, 02:02 PM
martysmartie
martysmartie's Avatar
I think the OP may have resolved the problem by now
Martin
Old 14-12-2014, 03:03 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Wow, I think you may have just massively overreacted Jano.... I was just giving my opinion!
Old 14-12-2014, 03:08 PM
Roscopeco
P8 Managed S1 with ALS
Roscopeco's Avatar
Tbh Karlos I can see why , you do seem to have more than a few sly digs at Jano for some reason
Old 14-12-2014, 03:09 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Not digs mate, I just don't agree with a lot of what he says.... Just different opinions that's all.
Old 14-12-2014, 03:12 PM
Fezzrs
Fezzrs's Avatar
Omex or pectel is only needed for massive power or track days im more than happy with weber l6 on my cvh its a lot cheaper than omex kms and does an effective job
Old 14-12-2014, 03:43 PM
studabear
studabear's Avatar
How did you come up with that conclusion.?
Old 20-12-2014, 10:59 AM
saman
saman's Avatar
The car is sorted it was wiring the car is running now. About the cosworth management I would not change its a good system an I'm happy with the management and the work jano has done he top guy.
Old 21-12-2014, 07:48 PM
RSricRS
Long live the ford RS'S
RSricRS's Avatar
Never heared so much bollocks in my life!
Old 11-03-2015, 09:06 AM
Fezzrs
Fezzrs's Avatar
I dont talk bollox pal i tell it how it is i agree with jano cossie managent is the best out there for the price so stop bitching lol
Old 11-03-2015, 02:33 PM
RSricRS
RSricRS's Avatar
What on earth you on about!!??!! You said omex is only for massive power cars which is complete bollox! i know lads running omex on 200+ bhp cars and even NA zetecs. You can pick them up for 500 second hand with loom. And am not bitching, am just trying to educate PORK!!!
Old 11-03-2015, 05:29 PM
Roscopeco
Roscopeco's Avatar
Now now girls
Old 11-03-2015, 10:21 PM
RSricRS
RSricRS's Avatar
Hahahaha he started it lol
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
jay030787
18-09-2015 07:34 PM
kosienutter
31
22-08-2015 09:55 AM
dlwarrior
05-08-2015 10:19 AM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: Cosworth management s2 no spark no fuel pump priming?
