Pink relay
Pink relay
Hi, my pink relay melted today and I've replaced it with a brand new genuine one but the fuel pump doesn't prime however it does start and run and the fuel pump works when the engines running. Is there an issue with the new relay? Fuel pump is about 2 years old and is a genuine Bosch
Thanks
Thanks
You need to find out why it has melted. I wouldnt be putting a new one in if that melts too.
Check the wires to the fuel pump have a clean connection. Check the wires to the replay plug are good
DixieTheKid
11
06-06-2020 11:20 AM
