CG Motorsport clutch
Hi,
My standard (genuine ford) clutch has started slipping badly after 300 miles so I am after an uprated clutch. Current spec is pretty average, fmic, exhaust, filter, -31 and 14psi. I would like a clutch that will good for 200+bhp/lbft to give me scope for the future.
Has anyone used CG motorsport clutches in 200+bhp rs turbos?
http://www.clutch-specialists.co.uk/..._p23368841.htm
I am likely to go with AP otherwise, even though the CP2000-8 kit is rated a 169lbft from searching it looks like its good for upto 230bhp/lbft?
Should I be looking at the CP2000-35 kit?
I did skim flywheel and will be skimming it again to be 100% sure everything is ok.
I don't really want a paddle clutch so I'm swaying towards the 2000-8.
Chopshop85 - Did you do the pedal conversion and have your flywheel skimmed when you fitted the clutch?
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
