Which wheel nuts for cosworth alloys??
going sideways in a fwd
I mean the collars need to be bigger than rst ones,
mate got some over the counter for cosworth wheels on a mk2 orion
you can get the rst ones off with a hacksaw but up to you
over the counter should be possible
Ok mate I'll ring euro Tomoz. I know there was a company that could make them up from nuts n threads but properly. I was going to see if somewhere could do the same but using my st220 nuts as there alot bigger Thant Rst ones. If you get me? Cheers anyways mate
Might be wrong but i think what your probably after are ghia wheel bolts.
Should be able to get them from eBay. Got mine from my local oval race track supplier.
Fleet Manager
I did a stud and nut conversion rely easy drill all the holes out to 12.mm and the studs pullin into the hubs I used an old steel wheel but some Washers and an air gun
Do the studs just tap in? I'd go for that mate as my threads in hubs are ancient so at least it would all be new etc . Couple of bolts just feel like they wanna keep turning after I've tightened them and that was before the cossie alloys! If you get me?
You ideally wanna press them or pull them in.
If you pull them in use a old steel wheel type wheel nut and 3-4 washers and tighten the nut against the washers which will pull the splines of the studs into the hubs.
Cheers mate. So drill them out with a 12 mm hss bit and pull them through. Where can I get some and what length studs?
JoeyBoyden
04-01-2024 02:36 PM
rst-s1
23-08-2015 07:56 AM
RSMK4TURBO
19-08-2015 04:46 PM
