master cylinder
master cylinder
hi all could you tell me if you use a different master cylinder when using a bigger brake upgrade, i am using cosworth 4x4 discs and calipers. abs has been removed and the master cylinder at the moment has the four outlets, does every one find this ok, i seem to have a lot of travel befor it seems to do any thing. i would be gratefull for any advise. cheers frankie
