Ford Escort RS Turbo Heating Problem
Old 24-04-2014, 09:11 AM
Sava Ford
Sava Ford's Avatar
Default Ford Escort RS Turbo Heating Problem
Hello friends, i have RS Turbo S2, with little larger T3 turbo (bigger blades) and i have little more fuel (we got more fuel from black box on ke jetronic) and everything is stock. We have problem with engine heating (i have sport cooling radiator from UK) and stock intercooler. Can we help me with problem with temperature? I will posted pic of my car and we have only two RS Turbo here in Serbia**i will waiting for answer and advice. I will write everything else if you need.
Old 24-04-2014, 12:37 PM
s1cab
s1cab's Avatar
Try an 82°c thermostat helped me when mine used to run hot. How hot is it running ?
Old 28-04-2014, 07:10 PM
Sava Ford
Sava Ford's Avatar
Default Heat
Thx for reply today we put 83 thermostat and now is little better, and set to fun turn on little earlier too now temp is on half. But engine is hot anyway. I have XR3i hood, and today also put RS Turbo original hood and hot air go trough 2 holes on hood. But I don't know, maybe I must buy bigger intercooler and 2 fans ?
Old 28-04-2014, 07:15 PM
s1cab
s1cab's Avatar
On a rst between half and 3/4 on temp gauge is fine. Maybe try bonnet raisers if it's still hot. Intercooler will only cool charge temps and because it mounts in front of the radiator it will increase the temp of your water abit
Old 28-04-2014, 07:33 PM
Sava Ford
Sava Ford's Avatar
Ok I want to buy this, what you think? and i want to buy chipped ecu, but don't know which to buy? we try yesterday to "turn off" ecu (we pull of hose from AMAL valve) and we got 1 bar from turbo, but unstable - 0.8 - 1.1 bar) and because of that i want unlimited boost ecu? thx you bro, here in Serbia nobody know nothing about this engine
http://www.ebay.co.uk/itm/FORD-ESCOR...item3a8e41bd25
http://www.ebay.com/itm/Mk4-Ford-Escort-RS-Turbo-S2-Airtec-Single-Pass-Alloy-Intercooler-Kit-RST-/121276594026?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c3ca5f76a
Old 28-04-2014, 08:20 PM
s1cab
s1cab's Avatar
Video Link: http://www.ebay.com/itm/Mk4-Ford-Escort-RS-Turbo-S2-Airtec-Single-Pass-Alloy-Intercooler-Kit-RST-/121276594026?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item1c3ca5f76a
Even if you buy a chipped ecu you will still need to get it set up correctly. You cant just increase boost pressure without adjusting the fuel to suit
Old 28-04-2014, 08:57 PM
Sava Ford
Sava Ford's Avatar
Ofc, but we can give more fuel via black box? when we make hybrid turbo (with bigger blades) and when we start engine first time, the car couldn't go, then we give more fuel with black box. is that ok?
Old 07-05-2014, 12:18 AM
Sava Ford
Sava Ford's Avatar
Anyone moreee ?
Old 09-05-2014, 07:45 PM
Sava Ford
Sava Ford's Avatar
https://www.youtube.com/watch?v=ao1X...ature=youtu.be
Old 08-07-2014, 09:34 PM
Sava Ford
Sava Ford's Avatar
Hi again. Now I need another help about my car. We do some changes on engine and now we have problem with fuel - lean mixture. We have about 200 hp and we don't know how to increase fuel. Increased fuel with back box, with ke jetronic, with bigger injectors but nothing. And now tomorrow will install 5th injector in intake. But we never do that before and need some advice. If someone can give advice about that, what to do and etc thanx brothers
Old 08-07-2014, 10:06 PM
mk2grp1
going sideways in a fwd
mk2grp1's Avatar
you have fitted -31 turbo actuator ? it a sierra cosworth part
Old 08-07-2014, 10:15 PM
Sava Ford
Sava Ford's Avatar
Yes, I fitted -31 actuator
Old 08-07-2014, 10:22 PM
mk1turboestate
mk1turboestate's Avatar
Have you fitted an unlimited boost ecu?
Old 08-07-2014, 10:33 PM
Sava Ford
Sava Ford's Avatar
yes, with evolution chip
Old 08-07-2014, 10:35 PM
mk1turboestate
What did the ecu cost out of interest?
Old 08-07-2014, 10:42 PM
Sava Ford
Sava Ford's Avatar
price + shipping about 120 euros - 95 b.pound
Old 11-07-2014, 04:45 PM
Red_bull
Red_bull's Avatar
Running lean will create heat and you can destroy your engine easy. Is ignition set right? If its too retard it will create a lot of heat. Make sure you know what you are doing else take it to a tuner can't say anything else then this. And with telling you have a turbo with bigger blades i get my doubts. No offence to you mate!
matman
09-09-2015 05:45 PM
dodge8283
27
19-08-2015 08:42 AM
adriansaleem
01-08-2015 09:28 PM
Quick Reply: Ford Escort RS Turbo Heating Problem
