Zetec sumps
28-03-2014, 09:22 PM
Zetec sumps
Does anyone know if it's possible to fit a silver top sump to a black top without too much work ?
A friends got a Capri with a poorly silver top Zetec engine fitted so was looking to fit a black top engine in it's place but seen as it's in a Capri the original silver tops sump has been modified to suit the rwd set up so was looking to swap the silver top sump over lock stock & barrel onto the black top engine.
28-03-2014, 09:44 PM
I think it's fine that way
It's when you put a black top on a silver top you need to do a little work
24-04-2014, 08:27 PM
Well did it swap over ??
as want to try the same
24-04-2014, 08:59 PM
Balls Deep!
Yes it does, you may need the pick up pipe too (can't remember 100%).
Balls Deep!
Quote:
Originally Posted by
lacey
A lot of work, bloody grinding dust everywhere!
lol
25-04-2014, 06:13 PM
caprizetec170
He's still messing about so not yet lol but it's looking promising that it will do.
25-04-2014, 07:01 PM
Karlos G
lol
Fancy doing mine for me ?
25-04-2014, 07:28 PM
You need the dipstick and tube also you need to have spacers made and the bolts from a silver top to fit the windage tray
25-04-2014, 07:47 PM
big.p
Spacers for what mate ?
26-04-2014, 08:42 AM
Balls Deep!
s1cab
No... I've just cleaned my workshop!
lol
26-04-2014, 08:58 AM
Karlos G
lol
Is there alot to grind out ? I'm guessing its where the 4 main cap bolts stick out thats the problem ?
26-04-2014, 09:05 AM
Balls Deep!
All the webbing you see here needs grinding flush..
It doesn't look like much but takes ages and makes a right mess!
26-04-2014, 09:21 AM
These bits ? excuse the messy lines done it on my phone
26-04-2014, 09:22 AM
Also do I then just need a blacktop dip stick and tube ?
29-04-2014, 07:04 AM
Is it just the bits ive circles above or does the whole lot need grinding out so it's like the silvertop sump ?
01-05-2014, 06:04 PM
Balls Deep!
01-05-2014, 09:35 PM
The spacers are for the big end bolts mate if you search on the net under mk4 zetec conversion there's loads of info pops up mate I bought a full 1.6 zetec engine and swapped the parts to the blacktop
mk3ste
17-10-2021 10:09 AM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
Iain Mac
30-09-2015 09:39 PM
mondeomark
28-09-2015 06:28 AM
youngben
27-09-2015 09:37 PM
