water leaking under fuse box
Old 08-03-2014, 02:28 PM
steve.rst
steve.rst's Avatar
Default water leaking under fuse box
I have water leaking under my fuse box on my 1987 rs turbo, I can see under the dash it is srewed to the bulkhead but cant see how to get to those screws from the fuse box, I take it I have to get the fuse/relay holder out first.
anyone give my some advise please.
steve
Old 08-03-2014, 02:52 PM
3i Jim
3i Jim's Avatar
Your correct. Pull the fuse box out of it casing. It's the casing that's screwed to the bulkhead.
Old 08-03-2014, 04:02 PM
jamesdark
jamesdark's Avatar
Take the lid off the fuse box, grab hold of the wiring coming out of the front and sharp yank upwards, (or use a small flat blade screw driver to free the clips off starting at the front) this will free the fuse board from the lower casing, then there are three cross head screws two at the front and one at the rear to undo then you can lift the bottom casing up to have a look, but you only have a few inches to play with so needs a bit of juggling about.
Old 08-03-2014, 05:22 PM
steve.rst
steve.rst's Avatar
cheers for the replies, all done now, didn't want to risk breaking the plastic casing. dead easy once I knew how.
steve
Old 08-03-2014, 06:31 PM
simonmcf
simonmcf's Avatar
What's the plan to stop the water?
Shaunc
Escort Range
22-09-2015 06:38 PM
Flatlinedan
18-09-2015 12:41 PM
Rammer46
18-09-2015 08:31 AM
talon1
15-09-2015 10:27 AM
BRAMMER
15
14-09-2015 08:52 PM
Quick Reply: water leaking under fuse box
