Having a mare bleeding brakes on mk3
It's got cosworth 4 pots on front and disc conversion on rear. I tried bleeding them today and they felt pretty good n when I've started it up they were crap? Is there a specific way to do it. I started from furthest point back, do you need engine running when doing it or not?
Cheers mate, I've changed the master cylinder as other one was goosed but there still pretty spongy. Where can I get a pressure bleeder from mate?
Balls Deep!
Wedge had same exact post a week ago, Id also removed the abs aswell so was still running all the abs m/c. It went to the floor when the car was started, I left it for a day, went back and bled again and a ton more air had worked its way to the end and the problem was gone, solid as a rock
