Manifold - Turbo Gasket
Take it off,they waste of time and money. I had same problem. You can buy flange high temp paste if you really worried about leaking. You may find it leak a tiny bit when cold but once warm it will seal, without any gasket or flange paste. Nice uprated locking nuts do the trick.
I never run a gasket. the only time I did, it blew it to pieces first time on boost. two flattish surfaces are the better option even if there not 100%. once up to temp they should seal anyway unless there seriously warped
when i had my turbo rebuild 2years ago they put a metal gasket in between the manifold and the turbo and it's still holding .
haven't had a problem with it blowing or anything
JK12
33
26-04-2021 12:09 PM
Matt Baxter
16-09-2015 08:30 PM
