electric windows
electric windows
Right, I've got a slow passenger window however its only slow using the drivers switch. Use the psgr switch and its fine.
I've stripped the drivers switch down, cleaned up all the contacts and its made no difference at all. Continuity tested all wiring and its all good.
Could the switch still be the cause even tho its cleaned up :/
(Drivers side window is fine and fast so would only be half of the switch with issues)
Dunno what else to test before I start swapping out parts
I had this problem and it was the connector blocks behind where the speaker pods sit in the front pillar, i cut the blocks and re crimped the wire n all has been good since
So if the passenger switch is speedy (well speedy for an escort ) then it can't be the wiring imo. If the drivers switch didnt look so clean inside i'd just replace it. Cant understand where the power less is occuring
I did check the blocks but they are nice clean metal anyway
Balls Deep!
But the power for the passenger switch comes from/through the drivers switch.
Had the same as well. Cleaned everything which made a little improvement. Tried some other switches which didn't help at all
st170 breaking
Take the glass out
Clean off and replace the grease in the runners the motor linkage attaches to
The groove will be dry and crappy after all these years
Also worth dripping some wd40 down the rubbers where the glass sits
Once the fluffy texture is worn off you are left with glass on rubber which isn't slippery
Take the glass out Clean off and replace the grease in the runners the motor linkage attaches to The groove will be dry and crappy after all these years Also worth dripping some wd40 down the rubbers where the glass sits Once the fluffy texture is worn off you are left with glass on rubber which isn't slippery
chowfornow
14
05-01-2019 09:01 PM
