Quick question, s2 won't start
The posh are up!!!
I haven't put the inter cooler on yet, is this why it won't fire up? Also maybe not enough fuel in it, been standing for 3 years put fresh petrol in it, about 2 petrol cans worth, it's just turning over
The posh are up!!!
Fuel is only about 3 months old IDE say, yeh got spark, cracked the banjo bolts on metering unit and there wet, I've had everything refurbed in the engine bay, I can't see there being much wrong with it?
in the garage
If you're still on mfi it wont start if you've got the intercooler off as you have a massive air leak. Try putting the intercooler on and holding the flap down slightly in the metering unit while someone cranks her over. If your on mfi that is
in the garage
My car has been off the road since 2009 as ive been restoring it. When I came to start it up it took ages to get it going. I had to hold the flap in the metering unit down for ages. I had fuel coming up but there wasn't enough to get it running have you took the plugs out and span it over? You should smell if you have fuel upto the bores then.
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
