283 or 300mm willwood brakes?
"Ill check the stock"
Been looking at these willwood brake kits that are available, cant decide whether to go for the 283mm or 300mm size discs, has anyone had any experiences with these any pros n cons etc any advice would be helpful
Ben
Brakes = big as possible.
If you can fit 300mm then it's a no brainer. 16" wheels are the norm but some 4 pots will go under 15's at a squeeze.
Just make sure the caliper sent is for vented discs, not solid discs. Check fitment with pads in the caliper and see if the disc will slide between them.
Also what online store are you thinking of buying them from?
I got mine from burton power, and sent them back due to above problem. I had to wait about a month for them to come as Wilwood are a USA company.... They fu#ked up, not Burton Power.
the 283mm are vented discs the 300mm are bells and rotors with different calipers !!
u need 16s to clear them I run them on mine work spot on and were supplied by burtons about 5 years ago :O
