Cvh block cracking
Not Crazy, just Unwell
Good question! At a guess on a NA car probs 5K. Do that in a forced inducted engine and pressures are a lot higher in the cylinders. Pistons maybe able to take it with them being forged but the only other weak link is the head gasket or block.
I knew some one who was in 3rd gear at 50mph and went straight down to 1st just to show what would happen. Pistons through the block private land also
basically I was showing off with a few people in the car. they all had to phone for alift home after this happened
had to go forged after that for piece of mind all fully balanced
have a look at my resto on the car
see what u think
https://passionford.com/forum/restor...-new-pics.html
the last one i saw cracked was right across the front.all i can think of that made it do it was years of running with no antifreeze,just water...
Not a CVH (it's a VAG 1.8t) but check this carnage!
http://www.clubgti.com/showthread.ph...nk-pulleys-Bad
Aye, was put down to not having a crank pulley damper on it, had a Neuspeed 'power pulley' on it. Built by ex BTCC engine builders Swindon race engines too!
i dont think its revs or boost, but a combination of the both, abit like a zetec oil pump
one or the other is fine but with both it would cause alot of heat i guess
i bet most of the time the blocks crack when cooling, ive seen alot of rs's that after a good kick in have been fine untill you switch the car off the overheat and chuck water everywhere
Ben
Fatigue of the metal? Considering even the youngest CVH lumps are 15+ years old now, with the constant rapid heating/cooling, that has got to be a contributing factor?
Ben
They are extremely strong tho. Handling 500hp+ with little signs of stress in some cases.
The cvh was never gonna hit that mark. Around 300s the best your gonna get if built properly, and that's stressful.
It could have been a lingering weakness in the material that eventually gave way to heat, pressure, harmonics although unlikely but never rule it out
Ben
This is why I now have a blacktop zetec turbo, last year I had 3 cvh's in the bay, the second I driven 3 times and ripped it out again as it was cracked across the front, leaked when hot.
I decided I couldn't chance spending the money building a fully forged cvh in case it cracked.
