s2 rs turbo fuel pump relay
hello,can anyone tell me where the fuel pump relay is located?and what colour is it?my rs died the other day and after a couple of minutes detective work i found that the fuel pump wasnt powering up.i ran a wire from the battery to the positive terminal on the pump and it worked.so i am presuming its the relay as all the relevant fuses were ok.
i didnt try that,i was just trying a shortcut to eliminate the fuel pump.had a look under the dash and my relay is grey,would this be a pattern part?
I can't remember if there's more than one relay under there? Stock fuel pump relay deffo pink (I haven't had a S2 RST since 1998)
Why I asked if it started with just fuel pump powered, if there is no signal from distributor/ignition ecu, the fuel pump won't run on cranking.
Lee
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
