.36 ar exhaust turbine housing
hi there, does anyone know where i can get one of these, preferably good used condition?
brand new they are a lot, so someone who stocks good second hand ones would be good. the one i have is cracked unfortunately
i am looking at keeping the stock .36 size. if anyone can help with this it would be very much appreciated
cheers, dan
cheers, dan
i doubt you ill find a perfect one,i looked for ages,if yours held boost fine id reuse it, i have about 4 here all cracked but held boost fine
cheers for the quick reply. unfortunately i bought the turbo untested so looks like i might have to take a gamble with it. are there any particular areas where if there is a crack present that i should not use the housing? cheers, dan
there is a swirl in the casting which always crack,as mentioned i have about 4 here and all the same,
the only way would be buy a new housing but by the time you have done that ive seen near new stg 3 t3s at £300
try it before spending any cash
cheers, if you could take a look and let me know. funds are tight at the moment. i might also be after a sound (ish) condition s1 t3 turbo in standard spec. anyone know where i might find one? as long as there isnt massive play in the shaft, the turbine wheels are undamaged and have not hit the turbine housings etc...
