Ford Escort RS 2 Full Resto - My first attempt
Old 26-11-2012, 10:00 PM
  #81
cossirob
cossirob's Avatar
can i ask have you just cleaned the throttle body and fuel acumalator or did you pait it?
Old 26-11-2012, 11:18 PM
  #82
simonmcf
simonmcf's Avatar
Wire brush on drill, decreased, small brass brush, sand down, washed in white spirits and few coats of metallic silver
Old 27-11-2012, 06:55 PM
  #83
cossirob
cossirob's Avatar
cool might give it a go on a few bits on mine
Old 30-12-2012, 01:37 AM
  #84
simonmcf
simonmcf's Avatar
got to spend little time today sprucing up some parts. Really just an inspection,clean down and spray up. Need to pick up new trackrod ends.
Old 22-01-2013, 10:43 AM
  #85
simonmcf
simonmcf's Avatar
Little update - been busy with work but been picking up bits and bobs
ITG Panel filter so keep OEM box.
Oil presure gauge with a holder - need sensors
Boost gauge - have a few of these and think this is broke as not sitting at zero but came with a holder for a dash mod Im going to do
CVH valve compressor. Should come in handy soon enough
Oil breather - this is the wrong but so its for sale - im sure it could be universal fit
Injector plate - stripped down, changes injector seals, cleaned out and few coats of metalic paint. I have the lines on the wrong way around - DOH!
Old 16-02-2013, 10:55 PM
  #86
simonmcf
simonmcf's Avatar
Bit of an update - does not look like much but good few hours gone into it.
Started cleaning up the nasty casting marks. You can see that half of this one is done. So far I have taken down most of the rough edges and removed all the manky carbon build up
I also stripped down the rocker cover. Primed her. Sanded her and two coats of Ford Sea Grey. Its the same as the paint on the body work. Still needs another rub down and then clear coat.
Signed the contracts for the new house so should have the keys in the next few weeks which means I can pull the shell out of storage get her into my own garage and start building her back up.
Old 17-03-2013, 08:12 AM
  #87
s23rta
s23rta's Avatar
Mines a reshell into a bonus too, cars ropey but the shell is solid, that's all that mattered, looking forward to the updates on this mate
Old 17-03-2013, 10:56 AM
  #88
simonmcf
simonmcf's Avatar
Ah good man. Il get some updates up in next few days- been buying more stuff
Old 06-02-2014, 09:52 AM
  #89
simonmcf
simonmcf's Avatar
Hi all,
been a long time since I posted in this so I thought Id give a little update. Well some of you might know that I bought a house last March. It was built in the 60's and in serious need of work. The RS was safe in storage as this was a priority. The plan was to knock a load of walls, fit loads of steel, insultate the bejasus out of it, rewire, new plumbing, plaster every wall, new doors, floor kitchen and lots lots more. The wife and I moved in just before Xmas and have the place pretty cost with the final home straight now in sight, ie floor down stairs, kitchen and snagging. The garage will be getting the treatment also and plan to take the roof off in the next week or so. Then I can get the RS in and start the fun on that. I have manged to collect even more parts in the meantime ( dont tell the wife!). The work in the house was all done by myself, the wifes dad and a couple of his work contacts. Hopefully next time I post in here it will be a pic of the RS coming home.
When I bought it
During the works
More a less as it stands
File Type: jpg
File Type: jpg
Old 14-06-2014, 02:33 PM
  #90
simonmcf
simonmcf's Avatar
After a long long time of been locked up in storage I finally got her home today into my garage.
Can finally start putting stuff back on!!!
So where do I start? What's the best way of getting everything back on????
Old 14-06-2014, 03:27 PM
  #91
tlr_rst
tlr_rst's Avatar
do the outside first its quicker to put to all together outside then frees up some storage space.
or do the inside, can be down in about 4 hours, carpet seats, lining, and dash
Old 14-06-2014, 03:48 PM
  #92
simonmcf
simonmcf's Avatar
She is a complete bare shell , no loom and I'm replacing all four corners appreciate your advise. Any more advice?
Old 14-06-2014, 08:04 PM
  #93
tlr_rst
tlr_rst's Avatar
any more advice...yer....ya better get cracking
Old 27-10-2014, 06:43 PM
  #94
simonmcf
simonmcf's Avatar
Been a while since I updated this. Not much has happened as I only get a few hours a week on it and everything takes me ages to do. Good news I have decided to go efi and started to pick up the hard ware. Still need ecu and injectors. Next up is brake and fuel lines. All comments welcome..... Be nice!
Old 27-10-2014, 07:21 PM
  #95
luxembourgrst
luxembourgrst's Avatar
cool the door handle nice job
Old 29-10-2014, 12:23 PM
  #96
moesin2005
moesin2005's Avatar
loving the door handles
Old 29-10-2014, 06:43 PM
  #97
tlr_rst
tlr_rst's Avatar
take it you just used a seat for the fabric or can you buy the fabric?
Old 29-10-2014, 09:42 PM
  #98
simonmcf
simonmcf's Avatar
Yea I have material that I pulled off seats and door cards. I think twins on here might have some fresh off a roll to sell.
Old 30-10-2014, 07:28 PM
  #99
stembo21
stembo21's Avatar
Looks nice keep up the good work
simonmcf (30-10-2014)
Old 29-06-2015, 09:26 PM
  #100
simonmcf
simonmcf's Avatar
Been a long time since I updated this. Have the suspension totally renewed on the right front and rear wheels. This included new shocks, springs, bushes, tie rods. Also fitted new brake lines and fuel lines. Fitted the rad and intercooler- if you look closely you can see the pace intercooler peaking out. Have an efi engine there and started to renew the parts for it. All going well il be dropping the engine into her in the next month. Need to get an engine crane for a weekend.
Old 30-06-2015, 09:10 AM
  #101
Vicar
Vicar's Avatar
look forward to seeing the engine in
Old 06-09-2015, 06:07 PM
  #102
simonmcf
simonmcf's Avatar
Got a good two days at her today, starting to look like a car
Old 06-09-2015, 07:07 PM
  #103
Vicar
Vicar's Avatar
Looking good, making some progress now!
Old 06-09-2015, 07:29 PM
  #104
bigryrs
RSHoleinator
bigryrs's Avatar
Awesome mate keep it up
matman
09-09-2015 05:45 PM
cossie_chris
39
31-08-2015 11:58 AM
Jack and the Beanstalk
15-08-2015 04:27 PM
Quick Reply: Ford Escort RS 2 Full Resto - My first attempt
