fiat/406 brembos
Old 19-12-2010, 12:32 PM
zippyobrien
zippyobrien's Avatar
Default fiat/406 brembos
Are they the same as focus rs calipers, been told they are. Can get some cheap so was going to see if I can 'make' them fit my escort with some focus rs discs
I no the fiat runs a 305 mm disc.
Old 19-12-2010, 12:39 PM
Alps Pacino
Alps Pacino's Avatar
99% sure there the same
Old 19-12-2010, 04:51 PM
THEDMAN
THEDMAN's Avatar
They are the same.
I'm running them on my S2 from a FRS.
Old 20-12-2010, 11:59 AM
Rogeyboy
Rogeyboy's Avatar
What brackets / spacers are need to fit onto the S2 hubs with ST170 300mm discs?
Old 02-01-2015, 08:53 PM
rocus
rocus's Avatar
Default 406 callipers
been told by a guy that makes the brackets for the focus rs callipers to fit st170 that th 406 ones are totally different can any one shed any light on this as don't want to spend 150 on something that i cant fit
Thanks in advance
Old 03-01-2015, 08:06 PM
muz
Wye Valley Hardcore
muz's Avatar
I think the caliper is physically the same size, but the callipers have different sized pistons.
Old 03-01-2015, 08:25 PM
slammedorion
slammedorion's Avatar
Arnt the mounting lug set ups different?
Old 03-01-2015, 09:07 PM
Chas
Chas's Avatar
I am going to go against the grain here (after owning a couple of cars with Brembo brakes).
As great as they look I would look to another brake conversion or to make your existing setup better (be it a combination of better fluid, pads and callipers and discs from another Ford).
When the Brembos work they are great. However, Plate lift (which affects any Brembos with plates present for the pads to slide on) can increase refurbing costs, and even at home they can be a pain (the bolts which hold in the plates tend to seize in). Naturally you can live with them but the issue will always be there (you can grind down the backing plates to make the pads fit but there will always be a breaking point (and in this case a squealing point no matter how much grease you try to shove in).
Of course if you are after willy waving rights, then play on .
jason_nike
18-08-2019 10:53 AM
Wilsfoci
15
30-03-2016 10:26 PM
01-11-2015 06:53 PM
OrionRST200bhp
29-09-2015 08:30 PM
focus2351
09-09-2015 09:33 PM
Quick Reply: fiat/406 brembos
