| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
its far less of a headache to keep the zetec head.a standard blacktop head and cams with just a set of uprated valve springs will do 350hp
#3 |
lookin forward to replies as I am considering it too mate...
__________________
my mk4 Escort Bonus, ST170 + throttle bodies in OAP gold 193 bhp & 13.7 1/4 mile at 102mph http://passionford.com/forum/picture...16v-bonus.html |
#4 |
yh and me
#5 |
You already have the majority of the parts lol
Not sure what you will need to do with pistons as i don't know how different the combustion chamber volume is between cvh (specifically your head) and zetec. Gary above should be able to fill you in about that.. Your mount is adapted, you have an oil drain etcetc, and i assume you are on efi? So if compression ratios are no problem you should essentially be able to swap heads along with cam belt tensioner, water pump etc and be away. Rob, |
#6 | |
Quote:
#7 |
I will have a measure up of my cvh head then, if no one else know the chamber volume (im sure if i did a search it would pop up).
But essentially a cheap and easy conversion for any one with a zvh already installed and running. Rob, |
#8 |
an un skimmed cvh head is 60cc
__________________
#9 |
Balls Deep!
CR will be too high then I'd guess, how much does losing 12cc increase the CR by?
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk |
#10 |
i'm going the zetec turbo route later this year, forged pistons and steel H section rods, there's nearly a grand.
the rest is simple, just uprated valve springs, blacktop would be better as cams have better bearings and solid lifters i reckon on about £2k for a reasonable engine. |
#11 |
becuase im running a zvh turbo to put the blacktop head on would i need to convert to electronic fuel injection?
#12 |
Balls Deep!
Mate if your not going to run EFI then you may as well not bother, big waste of time
lol
__________________
#13 |
I would be intresting in doing a zetec turbo at some point maby when i have abit mre excperiance lol
__________________
Ford Escort RS Turbo, cossie managed, p8, coil pack, als, grs, baileys. Do it nice or do it twice - Carbon rs turbo. |
#14 |
that will be the first thing i will do then, convert to EFI
#15 |
surly its going to be easyer and cheaper to buy the blacktop efi head and convert to efi with that head instead of coverting with the cvh head and then replacing the head again? u get me?
is there any gd place i can purchase a blacktop head from or it a case of searching around? cheers |
#16 |
is it a blacktop bottom end tho? you can fit a blacktop head to a silvertop bottom end but you have to arse about with idler pullys, which imo aint worth it! get a compleate engine
#17 |
An eye for detail...
I got a 1.8 blacktop delivered with all ancils attached for £155. Im doing the while thing myself and trying to do it for cheap money. I'd like to prove that a modern reliable 220ish bhp blacktop can be done for very little money. For big power yeah you need to dig deep. But for reasonable power in a sub 1-tonne car, it can be done for half the big budgets.
__________________
'89 Diamond White XR3i EFi daily/fast road/show car: 90 spec, 4-2-1 tubular manifold, Piper 285 cam & 2" stainless exhaust, poly bushed, Spax adj all round, Tarox Strada pads. Cossie lattice's being refurbed for track sessions. '88 XR3i Cab project: Custom ITB's, Manifolds and Blacktop conversion, IB5 with Group N gear set + millions of details! Needs finishing ASAP as its gone on too long
#18 |
Like Karlos said mate, if you don't have efi there really is no point. Do this first.
tbh, you will probably pull 250brake with utter ease on a decent zvh, most people seem to get a solid 280 brake with out spending a fortune. Aston_b, IMO i think you can build a 300brake zetec for the price of a standard rebuild, a t34 and some pistons. Rob, |
#19 |
you build my engine with both manifolds and gt28/30 for about 3k and good for 350hp all day.
#20 |
Lol, better make that standard manifolds and 300 brake Gary, As im pretty sure very few people on here have your welding ability!
Rob, |
#21 |
first step will definatly be the efi before collecting bits for the zetec. After all I might just be satisfied with how it performs on efi and zvh. Have been looking at the efi conversion and seems rather much of a
, but I guess once you get started it'll begin making sense!cheers for the responses so far! |
#22 |
yeh cheers for all the info, how do i find out if i have a blacktop or silver top bottem end?
#23 |
#24 |
is there a simple way to work out if im running mfi or efi? aint had the car long and the guy didnt no exactly what was in it as its had alot of owners, it i no is that its xr3i chassis, 1990, but the 2.1zvh with the rs turbbo 1.6 head. im sure i read somewhere that after 1989 they changed from mfi to efi?
cheers |
#25 |
it is mfi after all just got the haynes out n checked
#26 | |
Quote:
__________________
#27 | |
Quote:
the fiesta ran an efi turbo lump so this is a popular conversion. if its efi chances are you'll have a big ally inlet with EFI stamped on it so its hard to miss ![]()
__________________
#28 |
this doing things in stages is why my tiny cvh runs a t34 so now i have my turbo custom manifolds that'll only need a flange change already running megasquirt so all i need do is swap engines over and as done in bits don't notice the cost as much and i'll still have my steel cvh to sell and get a bit back to put to the zetec but thats just the way i went about it and you can still have a working car as you do it rather than it coming of the road for months and a lot of people lose hope doing it in one large/daunting task
__________________
#29 |
So with EFI, apart from the mechanical bits needed, am I right in saying the current loom gets swapped by an XR3i loom. The current ecu gets replaced with an OFAB? No more dizzy as its run off coil pack?
I intend to around or over 1 bar so will I require another chipped ECU?, what about this aftermarket management - what is this replacing? the ofab? if so, is this megasquirt the main choice? Cheers Apologies for the basic questions |
#30 |
cant use a 3i loom you need a loom to match the ecu, or use the guide on rsbible i think it is??
megasquirt is a good cheep ecu ofab is the one for higher boost out of ofab and ofac as you can put a 3 bar cossie map sensor on allowing up to 2 bar of boost you will also reqire a efi tank and prob a better fuel pump |
#31 |
competant bodger
i would go aftermarket as opposed to fiesta efi as its a poor system at best for the money you will be paying to convert
#32 |
Balls Deep!
Also with aftermarket management there is no need to swap looms over, just cut back or tie back the old MFI loom that you dont need and use your shiny new loom that comes with your chosen management
__________________
#33 |
Hi Karlos,
Wouldn't I need to change the loom anyway if I was going to run efi?. Didn't realise I needed a EFI tank This Efi malark seems rather long! ![]() cheers |
#34 |
What?
You don't need an efi tank, the pump is external and you don't need an efi loom. With after market management such as megasquirt. You need an efi inlet manifold from a fiesta rst or xr3i (cvh) with fuel rail and wiring, a CPS sensor and essentially your away..... WB lambda is good, as is an ISCV etc but they are not essential. If your getting cold feet now mate i would probably leave it as it is..... |
#35 |
Lol, well I haven't started anything yet, but will be doing my homework before anything should start. We'll see how it goes for the moment whilst I get to know more about it. Regarding the loom, am I right in saying The current wires remain as they are with the efi wires , wired into the car?
If I intend to run 1bar or over, what should I be using? Thanks |
#36 |
As with anything you can get stuff cheap enough if you look around.
My Zetec had a big valve/port head, forged pistons, steel rods, new pumps, custom inlet, tubular manifold, GT30, Omex 600 and it owes me less than £1900 for the lot.
__________________
1968 Mk2 Cortina - Zetec turbo - 329bhp at 14psi so far... Classic Fords FTW! |
#37 |
Right loom,
You can essentially treat the engine loom as being two separate units, one is for things like the alternator, starter motor, battery, lights etc. The other is for the engine, so sensors, ecu, ignition etc. You (if using aftermarket management) keep the first loom (with lights and stuff) and make your own mini loom for your new ecu, which would have wires going to the EFI inlet (for injectors and most sensors), and wires for the cps and lambda. Have a look though old posts using the search button, specifically ones with megasquirt in the title as you will learn a lot from these (even if you don't end up using megasquirt) This is a bad photo of en efi inletm you can see it has the majority of sensors present a a nice connector for attaching to you new mini loom, ![]() This is pulled from the megasquirt web site but gives a good idea of what inputs and outputs a vehicle ecu has, most aftermarket ecus (and factory ecus) will have simular or identical inputs and outputs. ![]() This (at time of photo) was the most expensive table in the house lol but has some or most of the things on it you would need for a nice efi install ![]() and a picture of what a megasquirt ecu looks like ![]() Rob, |
#38 |
Cheers Rob,
That has certainly helped! But be warned I may need to pick your brains again sometime soon! Cheers |
#39 | |
Quote:
That seems a fair price, was that the engine in your black mk2? |
#40 |
__________________
| Display Modes | |
