PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Turbo
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 27-05-2010, 06:37 PM   #41
rstdave
Trader Score: (3)
rstdave is an unknown quantity at this point
Quote:
Originally Posted by Karlos G View Post
Valve float is not common really on CVH's, as I mentioned earlier the sprins rate is really high to start with so even if they were a little weak it should still be enough! lol
I'm using 20 year old springs as far as I know and have no probs with a rev limit of 7000rpm and thats with a Newmans cam and solid lifters.
Standard ford springs are indeed the ones to use over aftermarket ones it seems.....just for reference DO NOT touch Newman's own springs lol....the problems i had with valve bounce at high rpm were indeed down to their springs they told me i had to fit!
When i changed them for ford springs we measured the springs poundage, and the newman were 124pound compared to the ford ones at 185pound
Car revved happily to 7k afterwards
__________________
RS Turbo being broken......Focus RS now here!!!
rstdave is offline   Reply With Quote
Old 28-05-2010, 03:35 PM   #42
Karlos G
Balls Deep!
Karlos G's Avatar
Trader Score: (4)
Karlos G is on a distinguished road
Quote:
Originally Posted by OLDSKOOLRYAN View Post
can anyone tell me the exact procedure for fitting a new cam please.
i know i have to fit new tappets at the same time.
i think i have read somewhere that it needs to run in at 2500rpm for twenty mins ??? is this correct
thanks for all your help guys
Correct
Also make sure you use plenty of cam lube when fitting, both on the lobes and lifters, well on everything TBH!!
__________________
Zetec Turbo build in progress...
For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk
Karlos G is offline   Reply With Quote
Old 29-05-2010, 02:27 AM   #43
rsmark86
Trader Score: (2)
rsmark86 is on a distinguished road
you can get duplex 200lbs double valve springs from burton power for under £80
and newman cam is £124 and the solid lifters are 150
rsmark86 is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
