PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Turbo
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 20-03-2010, 07:29 PM   #1
dobermann1234
dobermann1234's Avatar
Trader Score: (0)
dobermann1234 is on a distinguished road
Default s1 rs turbo gear box
hi lads!
wots the best gearbox 2 use in my s1 rs turbo!
sum1 told me i can use a 6 speed box??
wots it out ov?
thanx jamie
dobermann1234 is offline   Reply With Quote
Old 20-03-2010, 07:35 PM   #2
Oranoco
Oranoco's Avatar
Trader Score: (0)
Oranoco is an unknown quantity at this point
The S1 box is a bit unique as it has pick ups for the anti roll bar setup. No box will be a direct replacement and loads of fabrication work will be required. Best bet is stick with the S1 box but get it built properly. A CTS box is a tough bugger, mines survived me and that's saying something
__________________
Some people say I'm bitter and twisted,
I say "Thanks for noticing"
Oranoco is offline   Reply With Quote
Old 20-03-2010, 07:37 PM   #3
dobermann1234
Trader Score: (0)
lol! wot sort ov money an were can i get 1 from m8?
Old 20-03-2010, 07:40 PM   #4
Oranoco
Oranoco's Avatar
Trader Score: (0)
www.gearboxman.co.uk
Price varies depending on what you want but a basic refurbed box is about £500 iirc rising from there depending on what you want, shot peened gearset, Quaiffe ATB etc
__________________
Old 20-03-2010, 07:42 PM   #5
dobermann1234
Trader Score: (0)
thanx m8 ill take a look!!
Old 21-03-2010, 12:13 AM   #6
morph
morph's Avatar
Trader Score: (1)
morph is on a distinguished road
if that option is too much for you, why not try a ib5 box which is a direct fit and much stronger with bigger bearings added bonus is that the box centralises easily in neutral unlike the bc.
morph is offline   Reply With Quote
Old 21-03-2010, 10:35 AM   #7
Oranoco
Oranoco's Avatar
Trader Score: (0)
Quote:
Not an option mate as it doesn't have the pickups for the front ARB setup. The box's casting is completely unique
__________________
Old 21-03-2010, 06:06 PM   #8
morph
morph's Avatar
Trader Score: (1)
Quote:
mines a ib5 box with no problems regarding any pickup. maybe the specialist used a s1 middle casing but it defo has no problems.
Old 21-03-2010, 06:40 PM   #9
Oranoco
Oranoco's Avatar
Trader Score: (0)
It must be IB5 internals in the BC casing as the S1 ARB set up bolts to it. The IB5 does not have the castings for this. and the S1 can't use a normal cradle as found in the S2 without dithcing the ARB setup.
If I'm wrong I'll eat my hat.
__________________
Old 21-03-2010, 07:11 PM   #10
Karlos G
Balls Deep!
Karlos G's Avatar
Trader Score: (4)
Karlos G is on a distinguished road
That would be an odd thing to do as it's only the bearings that are bigger and they are not what goes
__________________
Zetec Turbo build in progress...
For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk
Karlos G is offline   Reply With Quote
Old 21-03-2010, 07:23 PM   #11
dobermann1234
Trader Score: (0)
iv started sumthing now lol
Old 21-03-2010, 08:10 PM   #12
Oranoco
Oranoco's Avatar
Trader Score: (0)
Quote:
Yeah you bugger
__________________
Old 21-03-2010, 11:16 PM   #13
dobermann1234
Trader Score: (0)
lol i will stick wiv yr idea m8!
but u sud still eat yr hat tho lol!!!!!!!!!!
Old 22-03-2010, 08:26 PM   #14
morph
morph's Avatar
Trader Score: (1)
yes it is using bc late front, but all the rest are ib5, like the gearset, double syncro, packed bearings etc..
Old 22-03-2010, 09:39 PM   #15
jammerrs
Trader Score: (0)
jammerrs is on a distinguished road
the 6 speed commonly used (well when people put a 6 speeder into these anyway) is from an focus st170. but then youd want a diff as well which is an extra £5/600 before any fab work is done to make it fit. which is about the same as a rebuild
my advise would be to go for the cts box
does the rs1600i have a casing like that to hold the ARB then?
jammerrs is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
