| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
cheers, Jamie ![]()
#2 | |
Quote:
they were developed on the new evo10 fq400. Last edited by crazycage; 06-03-2010 at 10:21 AM. |
#3 |
i would go for 15"s for allround, cost and handling, t1rs are a great tyre/as are uniroyals
__________________
power is nothing without control |
#4 |
Depends how much you want to spend on tyres ?
15's are going to be cheaper than 17's and more plenty so 15's would be the choice BUT have you got bigger brakes ? if so then you would have to go 16's but then you'll find 16 inch tyres are about as expensive as 17's so maybe just stick with 17 or have 2 set's of wheels , road and track . |
#5 |
These sound like a good tyre, are they semi slick? Thats the only thing that lets the 888s down is how god damm fast they wear.Got about 3k miles out of my last ones
__________________
cheers, Jamie ![]()
#6 |
__________________
cheers, Jamie ![]()
#7 |
What do people think to pradas as alot of people seem to use them? or is it just because there cheap
__________________
cheers, Jamie ![]()
#8 |
if your gunna do track days why not just get some old rst/ cossie 15"s and stick some t1r tyres on, and use your rs7s for best? also what size disc do you run?
__________________
#9 |
__________________
#10 | |
Quote:
Have 310mm wilwoods.Think they will just go under 15s wont they?
__________________
cheers, Jamie ![]()
#11 |
they may just clear!
16"s would be your best bet for allround,in my opinion
__________________
#12 |
I've ran 15's and 17's for track work, and it has to be said 15" 888's are alot cheaper than 17's if you want to run a spare set of wheels to keep for the track only.
I used to run my 17's on the road and had the standard 15's on 888's which i took to trackdays, but i fancied trying the 17's so now have them shod in 888's and tbh i've found them better on track than the 15's, more grip and more traction out of corners. As i run coilovers i also wanted to use the 17's as when the car is corner weighted iit will throw it all out using different size wheels. If you're using yours alot on the road i'd definately buy some cheap track wheels and get some road tyres on your 17's, i don't think you see the full benefits of 888's on the road anyway as you never get enough heat into them!
__________________
![]() RS Turbo being broken......Focus RS now here!!! |
#13 |
Hi Dave,what size 17's are you running,any rubbing on the rear arch's??I just run 195/50/15's. Thanks,micky
__________________
![]() Engine built & live mapped by Norris Motorsport 01773 836274 For proper brake's and suspension kits,TCA's,Calipers,Disc's,Adj Topmounts,Compression Struts etc use COMPBRAKE,call Tony on 07770 210881 |
#14 |
I've got a few trackdays booked for this year, but I will be driving the car to them as it is road legal. 8x17 for me with 205/40/17 Paradas.
Need the 17's to clear my Focus RS Brembo's.
__________________
#15 |
#16 |
Fleet Manager
15x7's mate dont have the tyre choices in 16s
__________________
![]() Click to see my RS Turbo project http://passionford.com/forum/showthr..._g#post3406438 |
#17 | |
Quote:
__________________
#18 |
im gonna be using 8jx17's on mine with 210-620-17 slicks
if that fails i also a few sets 8jx16's not got any tyres for these yet tho if was starting again i would go back to 15's tho just because of tyre choice and prices
__________________
#19 |
gus you have too many wheels
personally you cant beat the standard size wheels for tracks
__________________
#20 |
Guest
| Display Modes | |
