PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Turbo
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 06-03-2010, 08:35 AM   #1
chrism_rst
chrism_rst's Avatar
Trader Score: (0)
chrism_rst is on a distinguished road
Default Help with missfire / oil cap popping off
My S2 was running ok lastnight until i took went for a run on the motorway. When i came off the car seemed like it was running on 3 cylinders. I pulled over straight away and when i poped the bonnet the oil cap had come off. I let it cool down checked the oil and that was ok but now evertime i start the car it sounds like its on 3 cylinders and it pops the oil cap off. Does anybody know why this could be.
Any help is much appriciated
Thanks
Chris
chrism_rst is offline   Reply With Quote
Old 06-03-2010, 09:01 AM   #2
jaiscossie
jaiscossie's Avatar
Trader Score: (0)
jaiscossie is an unknown quantity at this point
Sounds to me like it could be time for a rebuild mate, piston rings could be worn which causes the cap to pop off.Really you need to get a leakage & compression test, leakage normally tells a lot more than compression
__________________
cheers, Jamie
jaiscossie is offline   Reply With Quote
Old 06-03-2010, 09:03 AM   #3
james kiely
Trader Score: (3)
james kiely is on a distinguished road
as above your rings are fooked mate
__________________
cheers james
james kiely is offline   Reply With Quote
Old 06-03-2010, 09:22 AM   #4
chrism_rst
chrism_rst's Avatar
Trader Score: (0)
I thought so hopefully get it tested today. How much would i roughly be talking to get it rebuilt back to standard? Thanks for the help.
Old 06-03-2010, 12:48 PM   #5
m4ttyrs
m4ttyrs's Avatar
Trader Score: (0)
m4ttyrs is on a distinguished road
The top post is very breif chris. Rather than "went for a run on the motorway" why dont you tell everybody what really happend. Ok so i will tell it as you. Last nite at about 1am when an m3 tried to come past me i thought f~#* that and gunned the rst, the m3 slowly started creeping backwards and me and my 2 mates were laffing our heads off, i then hit the rev limiter in 4th which let out a massive flame and a bang which is always good for the engine and looks really cool. Then with the sound of my mates shouting KEEP IT PINNED! into 5th i went and gunned it again still laffing and still pulling away from the m3. I didnt shut off untill the car was off the clock and the slip road was approaching the m3 was a dot in the distance which is when i discovered that the car wasnt running at its best and that 150mph run mite have done some damage so i pulled off to a side road to try and work out what could possibly be wrong. I came to the conclusion that 150mph combined with the fact that the car has been stood in the garage for 6 months and this was its first run out mite all be contributing factors. I think this is much more in detail Chris. All on a private test track obviously. ZVH time mate.
__________________
m4ttyrs is offline   Reply With Quote
Old 06-03-2010, 04:11 PM   #6
StephenC
..BS Motorsport..
StephenC's Avatar
Trader Score: (0)
StephenC is on a distinguished road
Quote:
love it
__________________
"be good, or be good at it..."
my photos on --> FlickR or view them in style at fluidr
StephenC is offline   Reply With Quote
Old 06-03-2010, 07:42 PM   #7
10th_racer
10th_racer's Avatar
Trader Score: (0)
10th_racer is an unknown quantity at this point
Send a message via MSN to 10th_racer
sounds like it was worth while to me lol
i'v done this a few times, when mine was stripped and inspected closer on 2 occasions it had cracked a piston, and the other 2 occasions it had melted a piston, all due to running weak, the pressure then coming back up through the head is what blows the oil cap off.
__________________
10th_racer is offline   Reply With Quote
Old 08-03-2010, 08:36 AM   #8
jonny s2
jonny s2's Avatar
Trader Score: (12)
jonny s2 is on a distinguished road
sounds like engine time
__________________
power is nothing without control
jonny s2 is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
