| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
#2 |
You can get the connector from ebay, you may still be able to get the sensor from ford?....
#3 |
Insane Bavarian
Thermo switch controls more than just the cold start injector. On n/a MFIs, it controls the cold start injector and the fuel shut off. In KE-Jets the ECU also gets the temperature from the sensor (it isn't a switch then) to control amount of fuel. So it should be connected correct to cure your hot/cold start problems.
#4 |
Im pretty sure the sensor/switch for the cold start valve is only used for the cold start valve, it has a small heating element in it and a bimetallic spring, which can fail.
You may be referring to the engine coolant temp sensor or the air temp sensor. Rob, |
#5 |
well only for the cold start injector or also for other things?
#6 |
what?
#7 |
where can i find a thermo switch sensor i d ont whant to go to ford
thanks |
#8 |
did you find a thermo switch? im looking for one at the moment and ford cant get them and bosch dont make them anymore, let me know if you found one and it solved your problem, cheers
| Display Modes | |
