PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Turbo
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 09-02-2010, 10:46 AM   #1
stafcio
stafcio's Avatar
Trader Score: (0)
stafcio is on a distinguished road
Default Should i repalce this camshaft?
hello everyone.
look at this camshaft, should i replace it? it is worn but not extremely.
__________________
stafcio is offline   Reply With Quote
Old 09-02-2010, 10:51 AM   #2
xr2wishy
Trader Score: (2)
xr2wishy is an unknown quantity at this point
if it's worn replace it.
have you mesured the lift on the lobes and compared them with each other?
if not, get a caliper out and measure them, if it's only the tiniest amount of variance you should be ok, but approaching 0.1mm is quite bad and will make some cylinders run leaner/richer than others.
xr2wishy is offline   Reply With Quote
Old 09-02-2010, 11:33 AM   #3
stafcio
stafcio's Avatar
Trader Score: (0)
no i haven't measure them. will do.
thanks for the advice!
__________________
Old 09-02-2010, 04:44 PM   #4
Karlos G
Balls Deep!
Karlos G's Avatar
Trader Score: (4)
Karlos G is on a distinguished road
lmao!! If you can see any wear then bin it!! The lifters will be worn also and so you'll be well down on power.
Make sure you change them together and run them in properly to have any chance of survival.
__________________
Zetec Turbo build in progress...
For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk
Karlos G is offline   Reply With Quote
Old 09-02-2010, 04:47 PM   #5
crazycage
crazycage's Avatar
Trader Score: (0)
crazycage will become famous soon enough
looks like there is no lobe left on the left hand side first pic,that will be number four cylinder i bet.
crazycage is offline   Reply With Quote
Old 09-02-2010, 05:04 PM   #6
rstdave
Trader Score: (3)
rstdave is an unknown quantity at this point
As above, to me it looks pretty well worn tbh, i've binned cams that looked no worse than that!
__________________
RS Turbo being broken......Focus RS now here!!!
rstdave is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
