| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
me and my SB!!!!!
#2 |
Balls Deep!
The only tip I can give is not to use the S2 gearbox, even the CTS Stage 2+ box's have been broken many many times, stick with the FRS box fella!
![]() Crazycage on here is the man to explain whats needed to fit it to the S2, i'm sure he'll be on with the details mate!
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk |
#3 |
i have broken a stage 2+ bernie box at brunters
was only runnin 18 psi and rev limited to 5k (not finished mapping) in a silver top zetec turbo 3rd gear was well properly munched! |
#4 |
you need to trim the inner wing a little for the box to fit in the hole lol, then its just a case of fabbin up all your mounting points and doing a hydrauilc clutch conversion the rest is easy.
p-s if you cant weld dont try it . |
#5 |
me and my SB!!!!!
nice cheers for the help.Dont surpose you know what the focus box can handle in terms of power,obviously with an uprated clutch
#6 |
..BS Motorsport..
crazycage, just thinking out aloud, with these inner arch mods, is it not possible to move the engine over towards the drivers side to give the room required or not? Never looked at it but was just wondering the other day.
#7 |
Guest
#8 |
me and my SB!!!!!
#9 |
Guest
#10 |
South lincs rsoc
most of the focus rs's with big power (350 odd bhp and same torques) use standard boxes and as crazy cage said above not that hard ahs long as you can be bothered to weld and cut and shut mounts. Plus you need custom drive shafts.
__________________
This space has been left blank intentionally. |
#11 |
we measured that option and still won't fit, also tried moving engine backwards to gain a little but still no good you need to take off about 15mm if my memory serves me right
__________________
#12 |
Balls Deep!
Just take a grinder the the engine/gearbox, soon get it in there!
lol
__________________
#13 |
#14 |
Balls Deep!
Yeah doesnt take much to do a tidy job, if my welding skills were better i'd do it for sure!
Had a few gearbox's fail at quite low BHP so would be nice to have something reliable in there!
__________________
#15 |
im seriosly looking at doing the box conversion has anybody got any pics of the mounts that they had to make?
how much work is it to modify the standard frs driveshafts? started fitting my hydralic clutch master cylinder yesterday thanks to karlos's guide :thumbsup
__________________
My project thread click below for a nosey http://passionford.com/forum/restora...rbo-build.html |
#16 |
Balls Deep!
Yeah i'll get round to finishing that when I get the box back in!! lol
Pistons arrived today so at last I can commence the rebuild!!
__________________
#17 |
shit happens
__________________
#18 |
Balls Deep!
lol
Yes mate, I had a valve seat drop from the head destroying my engine!!! ![]() So building up a new one, with a new block, forged pistons and rods (Wossner, PEC), and a repaired NMS head! If you want to see what happened look here.... http://passionford.com/forum/ford-es...use-found.html and here... http://passionford.com/forum/ford-es...0396-well.html
__________________
#19 | |
shit happens
Quote:
__________________
#20 |
Balls Deep!
lol Yes mate! One mission after another!!
__________________
#21 |
shit happens
i got some pics of mine on my fb, how would i get them off to post up? alot of u would be surprised, if the damage wasnt so spectacular i wouldnt av laughed at it lol
__________________
#22 |
Balls Deep!
Right click them and select 'Save As' then use www.imageshack.com or www.photobucket.com to put them up on here.
__________________
#23 | |
shit happens
Quote:
__________________
#24 | |
Quote:
ill post some pics of how i done it when i get time. |
#25 |
heres a some pic's that i have just gone and took there is very little paint if any as it the coversion was done in a rush last year for classic ford show !! so its all out over winter for some sealer and paint .
btw i run five mounts, two on the engine and three on the gearbox because i hammer mine hard off the line at the pod on 888s . Last edited by crazycage; 08-02-2010 at 06:23 PM. |
#26 |
fancy putting those shonky pictures up could of waited till i gave it a blow over for you to smarten it all up p.s like the new foot wear shame you lost the other leg though bet most people be surprised they're getting beat by a 1 legged hill billy
__________________
#27 |
whilst were talking about this conversion,if i put the silvertop zetec together with the focus rs box clutch an flywheel, can i get away with running the 1.8 sump? or does it have to be the 2.0 blacktop sump?
__________________
power is nothing without control |
#28 |
it will bolt to the 1.8 no probs but there will be two extra bolt holes in the bottom of the box doing nothing but so what i have never got round to putting them in mine lol.
#29 |
__________________
#30 |
pity i havent got any pics of my mounts/bay as we made that look a lot nicer. The inner wings are tapered in on both sides, seam sealered and painted it and it looks spot on.
Thing is, the above setup works -i've launched it at the pod with Micky t's and Gary has done countless more - it's goto have more than 50 full bore launches under its belt. Rick
__________________
Bespoke calibration and remapping, OEM & Aftermarket management
#31 | |
Quote:
but that said it does work very well and thats all that matters to me fuck what it looks like its no show car. Last edited by crazycage; 07-02-2010 at 01:46 PM. |
#32 |
defo mate
__________________
#33 |
competant bodger
i know with that box and a cvh if you lower the engine 20mm you dont need to cut the inner wing dont know if poss with a focus engine tho
#34 | |
Quote:
#35 |
Balls Deep!
Very tidy job!
__________________
#36 |
..BS Motorsport..
#37 |
Guest
Crazy u could have painted all the back panel too
![]() Look's nice BTW |
#38 |
#39 |
#40 |
gary that looks so much better and all your black bits are done just silver to go now be all together soon
__________________
| Display Modes | |
