PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Turbo
Welcome to Passion Ford!
Welcome to Passion Ford.
Closed Thread
Thread Tools Display Modes
Old 06-01-2010, 08:14 PM   #161
trooper1991
trooper1991's Avatar
Trader Score: (0)
trooper1991 is on a distinguished road
Quote:
Originally Posted by turboboss View Post
bigger wheels and more power which peaks over 7000rpm could try a taller final drive like a 3.58 diesel gear but if the car a cvh you might lack the torque no problem with a 16v zetec or zvh
bigger wheels are on the way as ive just bought my self a nice set of 4 pot brembos and 345mm discs can a cvh go about 7000rph as mine limits at 6,700rpm
trooper1991 is offline
Old 06-01-2010, 08:17 PM   #162
Rob_DOHC
Rob_DOHC's Avatar
Trader Score: (0)
Rob_DOHC is on a distinguished road
Yes you can move the rev limit up, should do 7000 rpm.......... for a minute or two lol
Rob_DOHC is offline
Old 06-01-2010, 08:19 PM   #163
trooper1991
Trader Score: (0)
Quote:
for a minute or 2???
what happens then .....BANG?????
Old 06-01-2010, 08:19 PM   #164
Rob_DOHC
Rob_DOHC's Avatar
Trader Score: (0)
Quote:
tbh i cannot tell you weather it is pulling 156 or not this is what "thegearboxman" told me with my tyre sizes and the rpm i was at because he worked it out
Yes, that is theoretical, if that works my 328 theoretically does 190 odd
Rob,
Rob_DOHC is offline
Old 06-01-2010, 08:24 PM   #165
trooper1991
Trader Score: (0)
Rob,
and where did u get that from?
Old 06-01-2010, 08:24 PM   #166
ZTSI
1991 FORD Fiesta
ZTSI's Avatar
Trader Score: (0)
ZTSI
Send a message via MSN to ZTSI
how hard is it to fit a focus rs box to a cvh?
ZTSI is offline
Old 06-01-2010, 08:30 PM   #167
Rob_DOHC
Rob_DOHC's Avatar
Trader Score: (0)
One or many of your con rods (are they standard) shits its self, your block in normally its sphincter lol
Load on con rods rises dramatically with engine rpm, more boost is actually less stressful to a conrod than more rpm.
Rob,
Well the car does 90mph @ 3000 rpm (auto with converter lock out) so therefor it must do 180mph at 6000 rpm and 190 @ the 6400k rev limit?
Rob_DOHC is offline
Old 06-01-2010, 08:33 PM   #168
Rick
Trader Score: (0)
Rick is an unknown quantity at this point
Send a message via MSN to Rick
Quote:
You can't it's rear starter.
__________________
Rick is offline
Old 06-01-2010, 08:33 PM   #169
trooper1991
Trader Score: (0)
what does the car actually do at the rev limit??
Old 06-01-2010, 08:34 PM   #170
Rob_DOHC
Rob_DOHC's Avatar
Trader Score: (0)
Oh SHIT, i've just checked my book and it says it only does 145!!!! WHATS WRONG!
you see my point, theoretical top speed as determined by gearing is very different to what the car can actually do. Your car will not do 156 as it cannot pull 6,000 rpm or what not in 5th. So messing with bigger wheels and different gearing at the moment means nothing to you.
Rob,
Rob_DOHC is offline
Old 06-01-2010, 08:35 PM   #171
Rob_DOHC
Rob_DOHC's Avatar
Trader Score: (0)
Im sure it will do 156mph at the rev limit.... If only it could get to the rev limit
Rob_DOHC is offline
Old 06-01-2010, 08:36 PM   #172
Christian and Beccy
Trader Score: (14)
Christian and Beccy is an unknown quantity at this point
Send a message via MSN to Christian and Beccy
So, with the way this thread is going, it will be more a case of who hasn't done 170mph soon then?
I'll be interested to revisit this at the end of the next season and see how many of the wannabee's actually managed to achieve it.
My CVH made 7000rpm to do 171mph. Oli's made 7400rpm to do 173mph. Takes some mean feat to get a CVH to not only hold itself together at that engine speed, let alone actually produce useful power up there. Infact my previous spec had the limiter set at 7400rpm, but the torque fell off at 7000rpm. The later spec was still going at 7200rpm.
I think to do 170+mph, you'll need to be making hefty torque, like 280lb/ft at 7000rpm and have the right gearing, along with all the other links in place.
The will to want to do it isn't enough. Trust me.
__________________
Christian and Beccy is offline
Old 06-01-2010, 08:39 PM   #173
Christian and Beccy
Trader Score: (14)
AND in the distance.
Doing 170mph is one thing, doing it AND stopping at Brunters is quite another.
If I'd have been given 2.5 miles THREE or FOUR years ago, I'd have done 180mph then and more recently 185+mph, but the point of the top speed record is that its a measured distance too.
__________________
Old 06-01-2010, 08:39 PM   #174
trooper1991
Trader Score: (0)
ok then pal tbh i aint really fussed i know what the motor does as i drive it and i have done it !!!!
Old 06-01-2010, 08:40 PM   #175
Rob_DOHC
Rob_DOHC's Avatar
Trader Score: (0)
lol, Christian, your missing the point. My RST will have a 170 TERMINAL velocity and for under a ton. WATCH THIS SPACE.
Rob_DOHC is offline
Old 06-01-2010, 08:45 PM   #176
Christian and Beccy
Trader Score: (14)
__________________
Old 06-01-2010, 08:45 PM   #177
Rob_DOHC
Rob_DOHC's Avatar
Trader Score: (0)
Look this car can do it too.
I think it will cost me under Ł100 to find a large enough cliff to win the rst top speed challenge.
Rob,
Rob_DOHC is offline
Old 06-01-2010, 08:48 PM   #178
Christian and Beccy
Trader Score: (14)
Rob,
Or maybe drive it out of the back of a Hercules at 30,000 feet, you might hit 300mph.
__________________
Old 06-01-2010, 08:48 PM   #179
morph
Trader Score: (0)
morph is an unknown quantity at this point
Quote:
Originally Posted by d4 rst View Post
I THINK YOU MISS YOUR RST 350BHP YOU WAS TOP DOG ONE TIME.
I would if i had a 230bhp car to replace it with too!
morph is offline
Old 06-01-2010, 08:50 PM   #180
Rob_DOHC
Rob_DOHC's Avatar
Trader Score: (0)
lol got big hills in Spalding then?
Im only taking the piss mate, but seriously have a look through a few old posts by Christan and look at the effort he went to to get 170.
Then have a look through the performance form mag (i think its in pf not ff) at the achievements page, and look at the top speeds achieved by folks in there, i think 240-250 brake lets you touch your rev limit in 5th, but if your car does it then congrats it must be a fit little lump you have.
Rob,
Rob_DOHC is offline
Old 06-01-2010, 08:52 PM   #181
Rob_DOHC
Rob_DOHC's Avatar
Trader Score: (0)
Sorry guys i've got to be boring and say that 230 brake of new megan would be more fun than any rst i can think of to live with, it probable even handles too lol not as much character or style though
Rob_DOHC is offline
Old 06-01-2010, 08:53 PM   #182
Christian and Beccy
Trader Score: (14)
Quote:
A 230bhp car with loads of tuning potential IF I can be bothered to do it, but for now I can drive it whenever I want, in great comfort (proper Leather Recaro's, proper Xenons, Climate control etc etc). They have a MUCH better chassis out of the box than the RST too.
I do miss my RST in some ways, but generally not and if someone came along tomorrow and offered me a swap for the most sorted proper RST ever built, I'd still say no for sure.
__________________
Old 06-01-2010, 08:53 PM   #183
jonny s2
jonny s2's Avatar
Trader Score: (4)
jonny s2 is on a distinguished road
i remember reading about a white s2 with severn valley stickers in 98 i think 300hp on k jet,and also ran stupid 11.99 sec quater miles at york race way
__________________
NMS cvh turbo track car
zetec bonus on bike carbs
moonstone blue 16v turbo
jonny s2 is offline
Old 06-01-2010, 08:54 PM   #184
franky_db
Surrey RSOC Photographer
Trader Score: (0)
franky_db
Christian - Im also looking forward to seeing peoples attempts this year. Will be interesting. Definately looks like theres going to be a few burst bubbles.
__________________
************ Surrey RSOC Official Photographer ************
franky_db is offline
Old 06-01-2010, 08:54 PM   #185
Christian and Beccy
Trader Score: (14)
Quote:
LOL, that was the one that did the spurious run. Only did that time ONCE that day and it really looked like a timing fault. Was alot of talk about it back then, can't remember the details, but certainly got discredited.
__________________
Old 06-01-2010, 08:56 PM   #186
trooper1991
Trader Score: (0)
Rob,
like i said i have no actual proof and im not making any stupid claims that i have something like 400hp or anything like that? i have never done a top speed run at brunters but hopefully will be going this year when i get my car all built up again, i have only had the car a year and tbh i am still not 100% sure what has been done to it i know its on my last printout 208bho with 230ft lbs of torque, its running on an mfi m2 and it has yes get this ...... 8 injectors which nobody seems to believe until they see but also i dont know if it has any great effect on the performance, the previous owner had this done?????
Old 06-01-2010, 08:57 PM   #187
Rob_DOHC
Rob_DOHC's Avatar
Trader Score: (0)
Sound interesting mate (genuinely and im not taking the piss) would love to see some photos if you could.
Rob,
Rob_DOHC is offline
Old 06-01-2010, 08:58 PM   #188
jonny s2
jonny s2's Avatar
Trader Score: (4)
i wouldnt really drive a 300bhp escort every day anyway,the reno is much newer and got more technology you cant really compare an 80s hot hatch with anything new, but you have done a good choice to go new skool
__________________
jonny s2 is offline
Old 06-01-2010, 08:59 PM   #189
trooper1991
Trader Score: (0)
Rob,
yer sure u got an email address???
Old 06-01-2010, 09:01 PM   #190
jonny s2
jonny s2's Avatar
Trader Score: (4)
Quote:
LOL yeah that was the one, more disbelief was fueled the fact it disapeared from the scene
__________________
jonny s2 is offline
Old 06-01-2010, 09:04 PM   #191
Rob_DOHC
Rob_DOHC's Avatar
Trader Score: (0)
Rob,
Just PM'd you mate
Rob_DOHC is offline
Old 06-01-2010, 09:05 PM   #192
Christian and Beccy
Trader Score: (14)
Top speed days always seem to have the same faces, but ever so often I've been and there have been a few new faces. Cars that are very little known and have all the promise of being great. I've seen cars arrive on trailers and I drive up in my little RST, with Beccy in the passenger seat and I really have thought many times 'this is it, this is the year I lose it'.
However, well, you all know the score. Only a handful of RST's have broken 160mph and only two with CVH engines have broken 170mph. Even including all those apparently serious cars that rocked up each year. Technology has come on, but not that much.
Most of these 'wannabees' manage circa 145-150mph at best.
__________________
Old 06-01-2010, 09:21 PM   #193
Christian and Beccy
Trader Score: (14)
Additionally, for those that are wanting a serious crack at the CVH RST top speed, I reckon you'll need to make AT LEAST 120mph terminal speed (more like 125mph) at Santa Pod to stand a chance. Looking forward to seeing your slips!!
__________________
Old 06-01-2010, 09:22 PM   #194
trooper1991
Trader Score: (0)
i wouldn't be going to beat anybody just too see wt my car can do
Old 06-01-2010, 09:54 PM   #195
rstdave
Trader Score: (1)
rstdave is an unknown quantity at this point
You'll need to get invited by a mag to go to brunters unless you're thinking of hiring it out, and they don't seem to be bothering so much with rst thrashes and the like as often as they used to! I'm afraid i totally agree with chistian on this one lol, there's so few 1.6 rst's that have done any proven times and i've seen first hand cars with so called 300+ struggling to 150 let alone 160/170......have a look through the old daddy thrashes to see various cars with all the minerals on paper that are just slow, end of! I'm into trackdays rather than an unuseable topspeed car so know my car will never be good for it, but i'm sure it takes a LOT of r+d year on year to get the results, plenty of people could most likely do it of they bothered and had the time/money and inclination but not many ever achieve it all!
__________________
RS's...u've gotta love em...but mine's usually broke!!
rstdave is offline
Old 06-01-2010, 10:09 PM   #196
Rob_DOHC
Rob_DOHC's Avatar
Trader Score: (0)
I think passion members should all contribute and hire brunters for the day, 100 cars and some 0-60/speed runs and a big bbq would be a good day
Rob_DOHC is offline
Old 06-01-2010, 10:12 PM   #197
morph
Trader Score: (0)
if i still have my car i will defo be up for this! good spring or summers day would be sweet!
morph is offline
Old 06-01-2010, 10:13 PM   #198
d4 rst
DADDY RST
Trader Score: (0)
d4 rst is on a distinguished road
Send a message via AIM to d4 rst
THAT WILL BE GOOD DAY OUT AND WE CAN SEE WHAT ARE CARS CAN DO .
d4 rst is offline
Old 06-01-2010, 10:26 PM   #199
Karlos G
Karlos G's Avatar
Trader Score: (2)
Karlos G is an unknown quantity at this point
Quote:
Where you at Modified Nationals this year?
Black S2 fitted with a ERL MF2 unit running 4 additional injectors fabricated to the back of the MFI inlet manifold?
EDIT: last year not this year!! (2009) lol
__________________
Lump is in!
Karlos G is offline
Old 06-01-2010, 10:43 PM   #200
Rob_DOHC
Rob_DOHC's Avatar
Trader Score: (0)
Ahhhhh i was wondering how the fuck this worked, thought some one might have used 4 additional standard injectors some how with some trick pressure regulator lol but your idea seems a lot more likely!
Rob,
Rob_DOHC is offline
Closed Thread
Tags
364hp! :d, chargecooler=fail, enhanced performance, hmmmmm, kosman can fart 364bhp, kosman jizzes @364mph, kosman makes dd rollers, most powerful cvh!, put it on a real dyno, turn your caps lock off
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
turbo d4 rst Ford Escort RS Turbo 9 30-01-2010 10:04 AM
I want 300bhp m66lry Ford Focus and Focus RS 3 06-12-2008 12:19 PM
the new 300bhp focus RS Lee Ivatt General Discussion. 42 09-07-2008 06:17 PM
Another 300bhp on the ASS dyno Dingy General Discussion. 4 25-02-2008 10:44 AM
Wot do i need to do to get 300bhp??? adamski frst Ford Escort RS Cosworth 23 13-08-2005 09:06 AM
Content Relevant URLs by vBSEO 3.3.0
