| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
#2 |
check for broken wire from the CPS sensor and ecu.
heard a few fail. |
#3 |
you should have a 12v at coil as it gets a switch live from iggy it fires by getting a pulse from ecu thats tells the coil to fire hence makes the spark, i'd make sure your getting a signal from cps first as thets the thing that kicks everything in to life, what ecu we dealing with
__________________
#4 |
indeed, start at the cps sensor, if you have access to a scope? or at worst a multimeter you should be able to get a reading. Then work your way back. I believe this goes into an ignition amp somewhere? before the coil any how, this has broken on my old mans xr4x4 a few times.
Good luck mate Rob, Last edited by Rob_DOHC; 30-12-2009 at 12:04 AM. Reason: retard spelling |
#5 |
Thanks, I will check all when it stops raining. The ecu is OFAC. Anyone know the correct air gap distance between sensor and crank wheel, I just closed it up till almost touching. Could it be to close?
__________________
#6 |
Back in black!
upski still has no spark
__________________
![]() My rebuild thread (2wd = proper cossy!) ![]() http://passionford.com/forum/restora...iny-stuff.html |
#7 |
Are you getting a reading at the EDIS? iirc its pin 5 + 6 for the CPS
__________________
Cheers, Danny ![]() |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| wasted spark.... no spark??? | B13 JUS | General Car Related Discussion. | 4 | 06-08-2009 07:09 PM |
| mk4 efi no spark | Toe Knee | Technical help Q & A | 34 | 14-10-2008 10:26 PM |
| s2 no spark ,help | f411hur | Ford Escort RS Turbo | 11 | 17-08-2006 11:32 AM |
| getting a spark | j65_xss | Technical help Q & A | 4 | 03-03-2006 02:11 PM |
| Got no spark. | Brasso | General Car Related Discussion. | 38 | 21-08-2004 08:00 PM |
