PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Turbo
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 06-12-2009, 08:22 PM   #1
Gregor
Trader Score: (0)
Gregor is an unknown quantity at this point
Send a message via MSN to Gregor
Default 1.8 zetec head onto 2.0
After lifting off the head of my 2.0 silvertop zetec turbo i found the camshafts were somewhat damaged along with the head due to pollution in the oil i think.
As a matter of course also removed the rods and the crank is also on it's way.
No i can get another crack here from a 1.8, should be the same but can't seem to find e decent 2.0 silvertop head.
Now i was told a 1.8 head will fit fine and the only difference is the combustionchamber is a little smaller.
But what about running the 1.8 camshafts on a little modifies 1.8 head go on this?
Or anyone got a good, complete silvertop head perhaps ??
Thanks.
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi
http://passionford.com/forum/restorations-rebuilds-and-projects/222915-zetec-turbo-on-megasquirt-new-turbo-arrived-gt2871r-p.html
Gregor is offline   Reply With Quote
Old 06-12-2009, 08:31 PM   #2
xr2wishy
Trader Score: (2)
xr2wishy is an unknown quantity at this point
you can fit the head, but will raise compression ratio, N/A boys do this with the zetecs.
but it will work though.
xr2wishy is offline   Reply With Quote
Old 06-12-2009, 09:13 PM   #3
Gregor
Trader Score: (0)
Thanks,
The chambers can be worked on a little to get the same cr i guess but how do the cams work , better/same or worse then the 2.0 ones?
And are the ports and valves the same size?
__________________
http://passionford.com/forum/showthread.php?t=222915
Old 06-12-2009, 10:29 PM   #4
Chris69
Trader Score: (0)
Chris69 is an unknown quantity at this point
Quote:
Originally Posted by Gregor View Post
Thanks,
I'm pretty sure there isn't much in it but i do know the cams in the 1800 are a bit milder than the 2litre.
__________________
Chris69 is offline   Reply With Quote
Old 07-12-2009, 10:00 AM   #5
xr2wishy
Trader Score: (2)
depends on what the 1800 head is off, you can use the 130 spec cams from the 2.0 without problems, i'd even say the ports/valves are the same, but you need to get teh 130spec head though, so escort gti really.
Old 07-12-2009, 01:01 PM   #6
Chris69
Trader Score: (0)
The gti didn't run the 130spec 1800- it was a 115ps version in the mk6 models.
130spec 1800 was only fitted in the mk5 xr3i officially.
115ps 1800 has milder cams- the 1800 130spec/2litre cams are one and the same.
__________________
Old 07-12-2009, 04:46 PM   #7
xr2wishy
Trader Score: (2)
cheers for that, wasn't entirely sure which ran 130spec.
Old 07-12-2009, 06:38 PM   #8
Gregor
Trader Score: (0)
Oki thanks guys,
Will be looking for a 1.8 130 bhp or a 2 litre head then..
__________________
Old 22-04-2010, 08:19 AM   #9
jordan99940
Trader Score: (0)
jordan99940 is on a distinguished road
So Just a quick question then is the 1.8 XR3i Cams and the 2.0 Cams the same and what about the XR2i Camshafts?
jordan99940 is offline   Reply With Quote
Old 22-04-2010, 01:09 PM   #10
Chris69
Trader Score: (0)
Quote:
1.8 xr3i came as a 105ps and 130ps, only the 130ps version has the cams that are the same the 2litre zetec.
i think the xr2i came with the 115ps cam setup as the 130spec ones where reserved for the fiesta RS1800.
__________________
Old 22-04-2010, 02:13 PM   #11
jordan99940
Trader Score: (0)
cheers so am i right in saying the rs 1800, 130 ps xr3i and 2 litre zetec have the same camshafts
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
will a 1.8 zetec head fit a 2lt zetec yellowrscustom Technical help Q & A 5 14-01-2009 10:32 PM
st170 head vs. zetec head. MD Cos General Car Related Discussion. 2 17-01-2007 09:40 PM
2l zetec head,pistons, rods, arp head bolts ludaprix Cars & Parts Wanted. 1 11-07-2006 09:59 AM
Can i fit a Zetec-E head to a focus CGI Zetec R Block Dub-Se7en Technical help Q & A 0 02-02-2006 10:00 PM
1600cc zetec 16v head onto zetec 1800cc bottom end weegaz22 General Car Related Discussion. 3 30-01-2006 03:37 PM
