| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
WANTED: XR3i SUPERCHIP!!! Pm me! Last edited by Dahl88; 24-11-2009 at 06:27 PM. |
#2 |
Hmmm. Does it have lambda input running to the ECU or do you have an aftermarket air/fuel ratio meter using it?
I'm not up on mainland Europe models but did they have cat's fitted to mk4's at all requiring the lambda input? What ECU does it run, 1AFA?? Lee
#3 | |
Quote:
Its a Lambda input running to the ECU, its original. =< Yes my car had a cat fitted (from the factory) My car is Danish but my engine comes from switzerland. And that means its a 1990 spec engine with cat and lambda (I removed the cat tho, making it 108 hp :P) Thanks so far
__________________
WANTED: XR3i SUPERCHIP!!! Pm me! |
#4 |
Fleet Manager
http://www.rsbible.co.uk/escort/efi.htm
this may help ,surely you can just disconnect it as you will not be using the same ecu dont think any fiesta came with lamba sensor and cat
__________________
![]() Click to see my RS Turbo project http://passionford.com/forum/showthr..._g#post3406438 Last edited by marky_g; 24-11-2009 at 07:05 PM. |
#5 | |
Quote:
__________________
#6 |
if your fitting an rs turbo engine you need an rs wireing loom. then you need the rs fuel system, and the rs brakes, its a mega job. oh yes, and youl need the rs gearbox!!
#7 | |
Quote:
Lee
#8 |
what if i have a 1990 xr3i efi cabriolet,and i bought a 1988 escort rs engine what is the best thing for me to do and ill do it
#9 |
#10 | ||
Balls Deep!
Quote:
Quote:
As above!
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk |
#11 | |
Fleet Manager
Quote:
i was goin to go down this route but fiesta engine came up i have fitted mine (as per RS BIBLE way) now but bastard will not start think im juts gonna get mark ar grove garage to look at it
__________________
![]() Click to see my RS Turbo project http://passionford.com/forum/showthr..._g#post3406438 |
#12 |
#13 |
Balls Deep!
All of Grandad Racers post!
lolYeah it is old, I hadnt noticed either!
__________________
#14 |
Insane Bavarian
XR3i EFI without catalyst wasn't available in Germany. So a non-catalyst one would be rare. Converting you car is the same as converting an XR2i 8V to FRST
#15 |
am i right or wrong to say i dont need an ofac or ofab ecu to do this job as my escort must have either one of them ecu ??
#16 |
#17 |
Fiesta t3
currently selling everything you require on ebay ecu, loom, map sensor, edis 4, co pot
#18 |
Its an easy job mate just read the rsbible quoted before, i did it mate n u can use an escort rst pump or drop the fiesta rst pump in top of ur xr3i tank. Ull need a meter of fuel line as feed n return pipe on pump face opposite way. As for ignition, feed n earths just wire through yellow relays x2. Just follow the diagram on rsbible
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| rsi cabbie,pics efi xr3i to efi turbo | rickbartlett | Pictures, video & Photoshop Forum | 8 | 24-06-2009 11:12 PM |
| escort xr3i efi to rs turbo | leers85 | Ford Escort RS Turbo | 1 | 05-09-2008 08:32 PM |
| xr3i efi turbo conversion | fatmike | Ford Escort RS Turbo | 7 | 09-01-2008 05:12 PM |
| EFI XR3I WHAT PARTS CAN I USE FOR EFI TURBO CONV | ford crazy | Ford Escort RS Turbo | 5 | 13-02-2007 03:58 PM |
| xr3i efi turbo | indy992000 | Technical help Q & A | 0 | 14-01-2005 12:39 PM |
