| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#41 | |||||
Balls Deep!
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk Last edited by Karlos G; 25-10-2009 at 08:29 PM. |
#42 |
Balls Deep!
Second thoughts......... having just seen a IB5 (Puma 1.7 to be exact) stripped, it's exactly the same as my BC box except larger bearings for the main shaft I believe.
So for the hassle of getting one and fitting my ATB diff, for very little gain I think i'll stick with my rebuilt BC box until it dies and then grab a IB5 with built in slave. After all, I stripped teeth off my input shaft when i killed my last BC box and that is still the same! ![]() But very good to know all these box options now i'm hydraulic!
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk Last edited by Karlos G; 26-10-2009 at 09:14 AM. |
#43 |
Unknown.
Cool conversion, MK had a hydraulic clutch on his XR2t.
__________________
GE - 1D - T |
#44 | |
Skint Passionford User
Quote:
There scrappy in Moretons got 3 pumas in now, i've already bought the linkages, will have to pop back and pick a box up.... |
#45 |
were of to neps this weekend to have a tinkle on mine going to try do this a slight different way as to make it a simple bolt in conversion with a moddified pedal box instead so could be a conversion we can simply post out to people and they swap peddle box over and send old box back to us then convert for next person and so on, if all goes well i'll post some pics up for you all to see and dave if your round over weekend call by and see if you want a manifold for exhaust to, as mine will be done by then, full stainless for 250 can't grumble at that and proven to over 400bhp so far
__________________
#46 |
Balls Deep!
Yeah that would be cool, i'm sure there are lots of people that would go for it!
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk |
#47 |
what car was the slave cylinder from ?
#48 |
Just a word about the wilwood master cylinders - make sure you've lined up the pushrod as straight as you can. I've had 3 or 4 fail now leaving me with no clutch, which leads me to believe they are either just shit, or they are very sensitive to misalignment.
The seals look fine on all of them, but the brake fluid goes dark grey and is full of ally. Witness marks on the metal pistons must mean that they are wearing the ally bore away causing sealing issues.
__________________
Cheers, Kev.
#49 | |
Balls Deep!
Dont know but i'm using a Nissan 300zx TT slave.
Quote:
__________________
#50 |
Karlos, can't you request a sticky for this one?!
__________________
" Dream as if you live forever, live as if you die today. " ![]() Check my project on http://passionford.com/forum/restorations-rebuilds-and-projects/207111-big-s2-rs-turbo-project-finished-lots-of-pics.html |
#51 |
you cant fit ANY rear starter box to a cvh.
#52 |
Wye Valley Hardcore
Why's that Gary? I had a late MK5 escort IB5 box with a cable clutch, rear starter and bar shift and I did end up using it on a full zetec but can't remember any problems when I tested it on a CVH.
__________________
![]() "BRAVERY IS THE CAPACITY TO PERFORM PROPERLY EVEN WHEN SCARED HALF TO DEATH"
#53 |
the standard oil cooler is there we tried yesterday and today we tried a late ka box with front starter which fits but twists the engine so it looks like a focus rally car at an angle so this week were going to try the method in karlos's sixth pic at top of thread
__________________
#54 | |
Quote:
#55 |
#56 |
Balls Deep!
First post updated with pics of slave fitted!
__________________
#57 |
sadly the cvh is different to the zetec engine, the oil filter is in a different place, on the cvh the starter would hit the filter, on a zetec the filter is over on the pulley side of the engine.
#58 |
After reading your initial post I specced up fitting the system but I found this slave cylinder:
![]() It's off a hyundai. I thought it would look more OEM when fitted as you can just trim down the clutch arm and fit it on a pivot pin over the arm. Just an idea for others! Quality post though mate! Lee
#59 | |
Wye Valley Hardcore
Quote:
I realised that pretty quickly when I thought about it after I posted lol ![]() Very interested in this conversion. If the pedal servo holds up ok I'll be doing this to the RST for sure.
__________________
#60 |
Balls Deep!
Just a final update!
Using a 0.75 MC with the Honda Prelude SC pictured it is way too heavy, I have dropped back to a 0.625 MC and is lighter now, although still heavy compared to other clutches but the AP Racing CP2000-35 is a very very heavy clutch in the first place! I'm guessing a smaller slave cylinder would also lighten things up a bit too! So if anyone needs a MC 0.75 thats done 35miles PM me.... Ł30 posted, was Ł50 from RD.
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk Last edited by Karlos G; 23-03-2010 at 07:40 PM. |
#61 |
bigger slave cyinder....
Depends if you have enough travel too.
__________________
Bespoke calibration and remapping, OEM & Aftermarket management
#62 |
Balls Deep!
Oh ok! Cheers Rick!
__________________
#63 |
__________________
My project thread click below for a nosey http://passionford.com/forum/restora...rbo-build.html |
#64 |
Balls Deep!
He used 0.75 mate which is what I used to start with but it was way too heavy, so dropped to a 0.625 which is better but still heavy!
__________________
#65 |
ricks is a .625 and its not heavy .mine is a .75 and thats not heavy feels like a standard focus . if your at the pod at the weekend pop over and have a go.
#66 |
Balls Deep!
Oh ok!
I think I might need a bigger slave as Rick says, or when I fit it to my new gearbox i'll move it further down the arm for more leaverage! Only way i'll be getting to the pod this weekend is if I walk!!
__________________
#67 |
Balls Deep!
Whilst I was fitting my trusty XR3i gearbox today I took the opportunity to move the SC right to the end of the clutch release arm for some more leverage as it was still quite heavy, and now it's incredibley light!! I actually thought something was wrong when I first pressed the pedal and got out to check the pipe was still connected!!
Those extra couple of inches make all the difference ![]() If you want to see where it was before check the first post.
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk Last edited by Karlos G; 19-04-2010 at 10:49 AM. |
#68 |
Would different size brake pipe make a difference I'm using standard small stuff on mine yours looks a bit bigger
__________________
#69 |
Balls Deep!
No mate mine is standard size.
__________________
#70 |
Karlos, can you not find a pull type slave cylinder and mount it where the cable would come through?? Would be much better instead of it dangling out in space.
Like this - http://cgi.ebay.com/ebaymotors/Wilwo...Q5fAccessories You might have to search for one the right bore size though, to go with the master.
__________________
Cheers, Kev.
#71 |
Balls Deep!
Yes I could, but i've seen one fitted and it looked shit and takes up loads more space!
lol
__________________
#72 |
[quote=Karlos G;4474518]
Big hole in bulkhead... ![]() what did you use to drill this hole mate? what size drillbit/hole cutter etc?
__________________
![]() mid-engined series 2 project now BREAKING http://passionford.com/forum/ford-rs...ic-clutch.html |
#73 |
Wye Valley Hardcore
You'll need a proper hole cutter, just buy a cheap set from Wickes.
One thing I will say though is I don't think it's possible to drill the hole the same size as the master cylinder (so it fits perfectly with no excess area around the cylinder) and have it perfectly lined up in one go. I measured and measured mine and connecting it all up it's not quite 100% square. It's not far out, but just off. So, I will be making the hole slightly bigger so thats centered then make a mounting plate up to so on the bulkhead I think. I really don't want my cylinder failing due to slight misalignment.
__________________
#74 |
so just some metal hole cutters then ? so its better to take my time to get the hole as perfect in line as poss.
__________________
#75 |
muz....
that maifold you have from crazycage, and are you using a T34.48 ? i have just got a manifold from gary (crazycage) do you just rotate the compressor housing on the turbo to line it up? also what did you do for the actuator bracket?
__________________
#76 | |
Wye Valley Hardcore
Quote:
Yes, I'm using a T34 .48 Cossie housing. With the manifold, I've spun the core and housing around. The alternator bracket will have to be fabricated. I haven't done this yet. I do have a standard mount which I'm going to see if I can modify. If not, I'll make one from scratch.
__________________
#77 |
cheers for that info mate !
__________________
#78 |
Balls Deep!
[quote=s1cab;5156755] I just used the biggest tapered drill bit I could get and then a dremel to open it out the rest of the way, sits perfectly centered behind the clutch pedal when looking up from underneath.
__________________
#79 |
for a 2.1 zvh with say 250 to 300 hp is the focus rs box the best to go for. what flywheel do you use and would i need to cut the chassis leg on my s2. what driveshafts are the best to use.
thanks |
#80 |
sorry for spammin your post karlos just readin about gearboxs and clutchs got me thinkin bout what i need
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Hydraulic clutch conversion | ybturbo | General Car Related Discussion. | 1 | 23-09-2009 01:21 PM |
| Cosworth 6 Paddle Clutch and Reyland Hydraulic Clutch Conversion | turbomook | Cars & Parts Wanted. | 1 | 17-03-2009 02:50 PM |
| hydraulic clutch conversion | stevieel | Technical help Q & A | 7 | 19-02-2008 10:39 AM |
| hydraulic clutch conversion | Niall.b | General Car Related Discussion. | 23 | 04-07-2005 08:51 PM |
| hydraulic clutch conversion for T5 | Vic | General Car Related Discussion. | 7 | 29-05-2005 03:31 PM |
