| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/restorations-rebuilds-and-projects/222915-zetec-turbo-on-megasquirt-new-turbo-arrived-gt2871r-p.html |
#2 |
Balls Deep!
Trumpets depending on size and shape will increase gas velocity which increases response, so long as they are not too restrictive, the oposite without them.
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk Last edited by Karlos G; 24-10-2009 at 12:02 AM. |
#3 |
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/showthread.php?t=222915 |
#4 |
Balls Deep!
I dont know! lol
Would need flow testing to be sure.
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk |
#5 |
my inlet has no trumpets and doesn't need them..it not restrictive and not laggy and doing good power.
#6 |
__________________
#7 |
#8 |
be interesting if you made another with trumpets just to see if improvements are made at all
__________________
#9 |
#10 |
sweet post up the graphs of each when done
__________________
#11 |
__________________
#12 |
#13 |
cosworth parts specialist
i made mine using a 2wd cossy inlet.
firstly i opened the trumpets out to 44mm id .then cut them off the manifold. then i cut out the center section and welded a 10mm thick plate in,with 51mm holes aligned to the zetec inlets. i then welded 51mm 10 guage tube into 1 side,and the trumpets on the other side. the tubes connect to the st170 inlet via a piece of samco type hose. |
#14 |
this is mine
![]() made by crezycage
__________________
#15 |
looks good
__________________
#16 |
anyone got pics of the inside of one?
#17 |
#18 |
#19 |
have no pics of mine but i have jeney throttle body trumpets welded in
__________________
#20 |
Skint Passionford User
Have you had chance to have a go at mine gary?
#21 |
so you have na style throttle bodies inside the inlet case thingy?
#22 |
sounds like a dig, but is a genuine question sorry
#23 |
yes i do
__________________
#24 |
__________________
#25 |
thanks but crazycage deserves all the credit as he makes them for us, it is easier to start without trumpets , will have another one knocked up in future with trumprts as we borrowed some out of a cossie and have the stuff to make another as above but will throw trumpets in and dave i've had him busy of late with a stainles manifold for the t34 but i'm sure he'll be straight on to it asap
__________________
#26 |
#27 |
am going to be making a new inlet manifold for my car, what should i take into account? should the t/b be on left/right side of the manifold? an could putting the sensors in the wrong place effect the flow?
#28 |
Nice one, no rush for it
#29 |
#30 |
another rover ....
my runs (600 + HP) ![]() ![]() but I now change........... |
#31 |
__________________
#32 |
__________________
#33 |
#34 |
__________________
#35 |
escort mk4 cossy 4x4
__________________
#36 |
__________________
#37 |
![]() and a random pic i think is very funny lmfao
__________________
#38 |
wats so good about the rover inlets ? always wondered
__________________
#39 |
Saw this on fiestaturbo.com:
Compatible OEM manifold and adaptor plate At the time of writing, the only OEM manifold that has seen use with the Zetec is the Rover 820 unit. this has medium length runners, a 1.8-2.0 sized plenum and the port shape is almost identical to the Zetec. The bolt patten unsurprisingly doesn't like up, so an adaptor plate is used. Tests have shown this manifold is capable of flowing enough for 360bhp. + Good port match and flow ability. - Limited availability. http://www.fiestaturbo.com/articles/zetecturbo/ |
#40 |
could you use the little trumpets you buy for carbs if they had the right internal diameter?
there quite cheap aswell rather than buying an inlet for its trumpets |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Inlet manifold Options? UPDATE GOT AN INLET! PAGE,2 | Gatecrasher | Ford Escort RS Cosworth | 73 | 14-12-2007 09:39 PM |
| Bike carbs (measuring size and making inlet manifold) | BRIGSPORT | General Car Related Discussion. | 20 | 23-01-2007 03:57 PM |
| Cosworth 4x4 inlet cam & inlet manifold | Nash | Cars & Parts Wanted. | 1 | 16-01-2007 07:36 PM |
| inlet manifold ??? | jamie rst | Ford Escort RS Turbo | 33 | 15-01-2007 06:30 PM |
| INLET MANIFOLD | Richie1Craw | Ford Mondeo (Including ST) | 3 | 15-06-2006 10:01 PM |
