PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Turbo
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 20-10-2009, 01:50 AM   #1
971slinger
Trader Score: (0)
971slinger is on a distinguished road
Default RS Turbo S2 starting problems
I am getting electricity from my Coil to the Distributor and to the Spark Plugs. All the multi plugs, Cold start Valve, Thermo Time Switch etc are pluged in correctly. Engine is cranking very good but not starting. I am also getting fuel to the metering head but not from the pipes to the injectors. Fuel is going to the Cold start valve and to the return. I think i might need a metering head, any suggestions. I need help. CheeRS.
971slinger is offline   Reply With Quote
Old 21-10-2009, 01:44 PM   #2
studabear
studabear's Avatar
Trader Score: (0)
studabear is on a distinguished road
Air leak is what I would be checking for firstly, check all boost pipes, servo pipe, breathers, oil cap seal, also try removing the air filter and hold the flap down a couple of mm on the metering head while someone trys to start the car
You don't really need the cold start valve connected, many people including myself run with them unplugged
__________________
Megasquirt project underway, hope my clutch can stand 20psi of boost
studabear is offline   Reply With Quote
Old 21-10-2009, 02:10 PM   #3
Matt carter
Matt carter's Avatar
Trader Score: (0)
Matt carter is on a distinguished road
Quote:
Originally Posted by 971slinger View Post
I am getting electricity from my Coil to the Distributor and to the Spark Plugs. All the multi plugs, Cold start Valve, Thermo Time Switch etc are pluged in correctly. Engine is cranking very good but not starting. I don't think i am getting any electricity to the Cold Start Valve. When i run a direct line from the Battery to the Cold Start Valve and crank up, the engine starts but dosen't idle because no fuel is reaching the engine from the Fuel Distributor. Could anyone tell me if i have an electrical problem, or if i need a Cold Start Valve or anything? I have been dealing with this problem for 5 months now, I need help. CheeRS.
My escort was not starting and was thinking must be electrical.
I had to change the metre unit on my rs
Is the fuel going through lines to the head.
Matt carter is offline   Reply With Quote
Old 21-10-2009, 02:24 PM   #4
Karlos G
Balls Deep!
Karlos G's Avatar
Trader Score: (4)
Karlos G is on a distinguished road
Barbados??!!!
I bet you dont see many RST's over there? lol
But yeah as above really, check the basics.........
Fuel to injectors?
Spark at plugs?
Compression?
If you have all three then you should at least splutter!
Air leaks are a common problem but generally you'll fire up and then die, try holding the flap down (under air filter) a few mm this will force fuel flow to the injectors whilst cranking.
__________________
Zetec Turbo build in progress...
For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk
Karlos G is offline   Reply With Quote
Old 21-02-2010, 11:35 AM   #5
atti
Trader Score: (0)
atti is on a distinguished road
Default RS TURBO
Hi m8 should the engine cut out when you push the flap down while running.because iv been avin starting problums.first thing in the morning it seems to splutter for about 5 mins.then runs ok ish the revs seem to go up and down abit on tick over iv checked fuel and air leaks .?
any help?
thanks
atti is offline   Reply With Quote
Old 21-02-2010, 11:42 AM   #6
rs_turbo_tony
rs_turbo_tony's Avatar
Trader Score: (0)
rs_turbo_tony is on a distinguished road
hi mate bit more info be good when was plugs changed have you heated plugs up and placed back in have you measured fuel pressure these cars will start with out cold start have you measured ohms resistance at sensors have you pushed down fuel meter couple of mm checked relays under dash pink and black did it play up befor becoming hard to start
rs_turbo_tony is offline   Reply With Quote
Old 21-02-2010, 11:46 AM   #7
rs_turbo_tony
Trader Score: (0)
Quote:
any help?
thanks
sounds like lifters empy oil when standing over night which causes misfire when did they last get changed or air aux valve / air leak have you had a spray around pipe joints with brake and clutch or easy start mate
Old 21-02-2010, 12:09 PM   #8
Karlos G
Balls Deep!
Karlos G's Avatar
Trader Score: (4)
This thread is from October of last year! lol
__________________
Old 21-02-2010, 03:15 PM   #9
atti
Trader Score: (0)
how do i gwt these things like ohms checked when i push the air padel down it cuts out!
Old 21-02-2010, 07:43 PM   #10
rs_turbo_tony
Trader Score: (0)
dont need engine running to check ohms you got workshop manual does fuel pump kick in
Old 22-02-2010, 06:02 PM   #11
atti
Trader Score: (0)
yer it primes ok and runns ok for 10 seconds the splutters for 1 minute then is ok.but a bit of smoke comes out when spluttering but never smokes any other time at all.?any ideas?
Old 22-02-2010, 08:10 PM   #12
rs_turbo_tony
Trader Score: (0)
may be valve stem seals these can be done with out takin off head
Old 23-02-2010, 06:17 PM   #13
atti
Trader Score: (0)
thanks for reply...
Old 23-02-2010, 07:22 PM   #14
DaveRST90
Trader Score: (0)
DaveRST90 is on a distinguished road
I suppose one thing you wont need to worry about with your RS Turbo being over in Barbados and that is rust With the weather probably hot 99% of the time and not that much rain most of the time your RS Turbo should be gleeming all the time? I've been to the Domincan Republic and the weather was amazing just hot all the time. In Scotland we get rain, ice and snow and it's not good for the RS Turbo's I keep my RS Turbo in our garage all the time and only really bring it out in the dry weather.
DaveRST90 is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
s1 rs turbo starting problems!? xrrs Technical help Q & A 1 13-05-2009 07:33 AM
Series 1 RS Turbo Starting problems Bigjohn Technical help Q & A 3 20-12-2007 09:06 PM
rs turbo starting/tickover problems Number1 Technical help Q & A 2 03-06-2006 05:39 PM
Problems Starting My Escort RS Turbo sometimes!!!! Larrys_RST Technical help Q & A 7 14-01-2006 09:34 PM
Problems with starting the RS! Larrys_RST Ford Escort RS Turbo 1 14-01-2006 06:34 PM
