PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Turbo
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 30-09-2009, 09:55 PM   #1
Chopshop85
Chopshop85's Avatar
Trader Score: (3)
Chopshop85 is an unknown quantity at this point
Default Handbrake light
Bit odd, if I apply my brakes at anything over 40mph the handbrake light comes on.
I always through the handbrake light was just a switch off of the old drift lever?
any help would be great.
thanks.
__________________
Chopshop85 is offline   Reply With Quote
Old 30-09-2009, 09:59 PM   #2
studabear
studabear's Avatar
Trader Score: (0)
studabear is on a distinguished road
handbrake light is low brake fluid warning also mate, your fluid is poss a touch low
__________________
Megasquirt project underway, hope my clutch can stand 20psi of boost
studabear is offline   Reply With Quote
Old 30-09-2009, 10:10 PM   #3
Chopshop85
Chopshop85's Avatar
Trader Score: (3)
Quote:
ahhh never knew that. However after giving my car a proper clean today I checked all my levels and all is cool.
__________________
Old 30-09-2009, 10:14 PM   #4
studabear
studabear's Avatar
Trader Score: (0)
possibly the sensor in the resovoir cap playing up if the fluids correct
__________________
Old 30-09-2009, 10:16 PM   #5
Chopshop85
Chopshop85's Avatar
Trader Score: (3)
i shall have a look when its light 2moro. i got a few spare caps if thats the problem, cheers.
__________________
Old 30-09-2009, 10:31 PM   #6
dangerousbrian
dangerousbrian's Avatar
Trader Score: (0)
dangerousbrian is an unknown quantity at this point
had a problem with my cap and connector also..but the light on the dash woudnt light up till i fixed it...
dangerousbrian is offline   Reply With Quote
Old 30-09-2009, 10:43 PM   #7
smcnairn
Trader Score: (0)
smcnairn is on a distinguished road
On the subject of brakes, mines a 90spec with ABS. Does the ABS have to be operational for he MOT? My ABS light warning light is not on ive linked it out. During an MOT the car would never lock up to prove the ABS isnt working so they would never know? am i right?
smcnairn is offline   Reply With Quote
Old 30-09-2009, 10:58 PM   #8
louie1
louie1's Avatar
Trader Score: (0)
louie1 is an unknown quantity at this point
The light needs to come on then go out to pass an mot.
louie1 is offline   Reply With Quote
Old 30-09-2009, 11:11 PM   #9
Zetecfiesta
Trader Score: (0)
Zetecfiesta is an unknown quantity at this point
Send a message via MSN to Zetecfiesta
my ABS never worked but it was all still connected up so i took bulb out and it passed every mot at a number of different garages and now ive removed it completly and it still passes mots no problem!
Zetecfiesta is offline   Reply With Quote
Old 01-10-2009, 12:08 AM   #10
Chopshop85
Chopshop85's Avatar
Trader Score: (3)
Yeah if the abs is removed the light has to be out and stay out. My MOT man let it slide first time, but said I need to get the bulb out.
__________________
Old 01-10-2009, 12:45 AM   #11
rs shawn
S1 Database Editor
rs shawn's Avatar
Trader Score: (0)
rs shawn is an unknown quantity at this point
Send a message via MSN to rs shawn
More likely to be corroded terminals inside the rubber plug onto the cap. These get muck inside and will go green when corroded. Give them a good clean out.
If you ABS light is on then it will probably be a snapped/ broken ABS belt or a microswitch has come out of the housing. There is a topic in here this week/ last week about it.
Don't just take the bulb out as a bodge job, get it fixed or remove the ABS system altogether. Neither are difficult to do.
__________________
D plate S1
Click Here For The Series One Picture Database
www.seriesoneturbo.co.uk - the site that caters for all Mk3 Escorts.
rs shawn is offline   Reply With Quote
Old 01-10-2009, 04:28 AM   #12
smcnairn
Trader Score: (0)
Yeah thats exactly whats happend the micro switch has came out of the housing. It will get fixed, the reason i asked is i have other jobs to do before the MOT and wondering if i can move this job further down my long "job to do" list.
Old 01-10-2009, 10:25 AM   #13
rs shawn
S1 Database Editor
rs shawn's Avatar
Trader Score: (0)
Takes 5 mins to do mate - definately quicker than removing the bulb. The microswitch just pushes back into the housing and should stay in place. I put some silicon around the edge to hold it more firmly to stop it popping out again. Easy fix.
__________________
D plate S1
Old 01-10-2009, 05:42 PM   #14
smcnairn
Trader Score: (0)
Thats good to hear, i had a feel about does the microswitch sit against the belt?
Old 02-10-2009, 12:35 AM   #15
rs shawn
S1 Database Editor
rs shawn's Avatar
Trader Score: (0)
Yes, the belt pushes the microswitch, making the connection. If the belt breaks then the m/s is released inside the housing & bringing the lights on.
__________________
D plate S1
Old 02-10-2009, 04:47 AM   #16
smcnairn
Trader Score: (0)
Cheers for that info mate, sounds like an easy fix.... relief!
Old 02-10-2009, 11:26 AM   #17
rs shawn
S1 Database Editor
rs shawn's Avatar
Trader Score: (0)
You've found where it goes, but there's a pictorial on here incase anyone else is unsure.
http://passionford.com/forum/ford-es...rd-lights.html
Chopshop: how did you get on with your problem?
__________________
D plate S1
Old 02-10-2009, 10:05 PM   #18
smcnairn
Trader Score: (0)
rs shawn cheers for the link to the diagam, looks a basic system. Looks like my problem is the micro switch hanging out as the belts are present and correct.
Chopshop: sorry for the hi jack of the link
Old 03-10-2009, 12:50 AM   #19
Chopshop85
Chopshop85's Avatar
Trader Score: (3)
Rs Shawn :took the plug off of the cap and gave it a bit of a clean up and its stopped the light from interupting my driving, so cheers for the advice on that one. Did have me miffed with the brakefluid at max.
smcnairn: no worries man, this way two problems have been hopefully solved by the helpful people of passionford.
__________________
Old 03-10-2009, 01:02 AM   #20
rs shawn
S1 Database Editor
rs shawn's Avatar
Trader Score: (0)
No problem. That's why we're all here isn't it? To help others out
__________________
D plate S1
Old 27-01-2010, 10:06 AM   #21
rslove
Trader Score: (0)
rslove is on a distinguished road
HELLO,
iv got s2 and my red and amber light are costantly on theres no abs on the car, and the fluid level is correct.
there are a few random wires under the bonnet but aint go a clue where they go!
the lights only came on the other week and dont really wanna remove the bulb anyone help???????????
cheers
rslove is offline   Reply With Quote
Old 27-01-2010, 07:34 PM   #22
project rs
Trader Score: (0)
project rs is an unknown quantity at this point
could be the switch on handbrake between seats is earthing out
__________________
project rs is offline   Reply With Quote
Old 02-02-2010, 03:33 PM   #23
rslove
Trader Score: (0)
Sorted it had carpet out to check 4 leaks! and noticed little bit of bare wire on the cable from the handbrake switch taped it up sorted must have been shortin on floor!
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Oil light and handbrake light not working on 2WD dash rog General Car Related Discussion. 5 21-07-2009 09:16 AM
Handbrake light Mad_Mike Technical help Q & A 4 02-04-2007 11:47 PM
handbrake light andre_k Ford Escort RS Turbo 5 08-03-2007 05:41 PM
handbrake light on S2 Hrsturbo Technical help Q & A 4 13-12-2006 07:37 PM
s2 displays no oil light/bat light/handbrake light etc RScrew69 Technical help Q & A 13 20-05-2005 12:59 PM
