PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Turbo
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 10-08-2009, 10:17 AM   #1
Antti O
Antti O's Avatar
Trader Score: (0)
Antti O is an unknown quantity at this point
Default RST With rear disc conversion pulls badly when braking hard
Hi!
I have sierra cosworth rear disc conversion completed wit all new parts.
Only old part is std brake bias valves. Brake bias (front/rear) itself is spot on but car pulls right badly when i brake fast / hard, in slow and easy braking there is no problems. Ive got 290mm sierra cosworth front discs too and braided hoses. Car was in brake dyno and there brake balance in rear was also good and there was no any problems.
I know car is very dangerous now. Do i have to change rear bias valves?
My koni adjustables are now all set to same so the problem is not in shocks.
Sorry my bad english.
__________________
S2 RST 1989 LHD / http://s2rst.blogspot.com/
Antti O is offline   Reply With Quote
Old 10-08-2009, 11:04 AM   #2
jammerrs
Trader Score: (0)
jammerrs is on a distinguished road
are they calipers not working on the left!?
jammerrs is offline   Reply With Quote
Old 10-08-2009, 02:34 PM   #3
Antti O
Antti O's Avatar
Trader Score: (0)
Quote:
Calibers are new and all working fine
__________________
Old 10-08-2009, 03:24 PM   #4
orion_crazy_carl
orion=mini saff
Trader Score: (3)
orion_crazy_carl is an unknown quantity at this point
Send a message via MSN to orion_crazy_carl Send a message via Yahoo to orion_crazy_carl
loose the standard bias valves, thats causing your problem!its unloading the the power from the back so the front is working harder so the back end goes light, u want more braking power to the rear wehn u have discs
IMO, loose the rear discs, there dangerous full stop!
__________________
WE HAVE ZE-TEC-NOLOGY!
Quote:
Originally Posted by Smartdj. View Post
....u cant comment u dont have an inlet
orion_crazy_carl is offline   Reply With Quote
Old 10-08-2009, 03:45 PM   #5
antony215
Escort Rs Turbo
antony215's Avatar
Trader Score: (0)
antony215 is an unknown quantity at this point
Quote:
Id agree with that there such a pain in the arse for little difference imo the only upside to discs is they look pretty
Standard drums are just as good.
__________________
antony215 is offline   Reply With Quote
Old 10-08-2009, 04:59 PM   #6
Antti O
Antti O's Avatar
Trader Score: (0)
I already sold std rear brakes..
But if i buy some proper rear bias valves and adjust them in same position? There is some valves in sale which have for example 7 different settings so i can adjust both sides in same.
__________________
Old 10-08-2009, 05:02 PM   #7
Karlos G
Balls Deep!
Karlos G's Avatar
Trader Score: (4)
Karlos G is on a distinguished road
If it's pulling badly to one side are you sure there is not a problem with one of the front brakes?
When my car did this it was because I had overfilled the gearbox with oil and it had come out the breather pipe all over my passenger side brake disc/caliper!!
__________________
Zetec Turbo build in progress...
For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk
Karlos G is offline   Reply With Quote
Old 10-08-2009, 05:05 PM   #8
Antti O
Antti O's Avatar
Trader Score: (0)
wow, what a theory!
I have to check that
__________________
Old 10-08-2009, 05:44 PM   #9
JamboRS
focus rs 1672
Trader Score: (0)
JamboRS is an unknown quantity at this point
rear discs are dangerous???so why does every performance car come with rear discs and perform well??
its badly set up brakes that are dangerous,rear discs will out perform any brake drum set up if set up proper,that includes master cylinder which most people forget about
JamboRS is offline   Reply With Quote
Old 10-08-2009, 05:57 PM   #10
Antti O
Antti O's Avatar
Trader Score: (0)
So whats problem with rs turbo master cylinder & disc brakes?
__________________
Old 10-08-2009, 06:44 PM   #11
orion_crazy_carl
orion=mini saff
Trader Score: (3)
from factory,yeah,abs set rear brakes,fine.
a rear light RST no abs,no, how can u set the rear discs up for every road type?
theres enuff storys on here of people crashing after converting to rear brakes, yeah, they might of needed setting up, but, it still happens!
__________________
Old 10-08-2009, 07:14 PM   #12
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
Trader Score: (0)
vroooom ptssssh is an unknown quantity at this point
Send a message via MSN to vroooom ptssssh Send a message via Yahoo to vroooom ptssssh
Actually, you want LESS power to the rear discs, think how much bias went to the original shoes, a lot to make them work....
mate, fit a bias valve, take some rear bias off and they will work fine
__________________
Passionford's realist, not to be mistaken for Pessamist!
My S1Resto
vroooom ptssssh is offline   Reply With Quote
Old 10-08-2009, 07:17 PM   #13
Karlos G
Balls Deep!
Karlos G's Avatar
Trader Score: (4)
Or just fit some big fuck off brakes up front to ensure they lock up first!
Not forgetting that will make the back go light too though
__________________
Old 10-08-2009, 07:24 PM   #14
morph
morph's Avatar
Trader Score: (1)
morph is on a distinguished road
or jsut adjust the compensator valve so it gives less bias to the rear mate.
morph is offline   Reply With Quote
Old 10-08-2009, 07:33 PM   #15
rst in breaking
Trader Score: (2)
rst in breaking is an unknown quantity at this point
Send a message via MSN to rst in breaking
when i had my escort on the road with my 6 pots and cossie rear discs i tested the brakes at around 130mph (emergancy stop) to see how good they were) mine stopped perfect with them with no skidding, admittedly the rear did start to get light eventually but braking hard at that speed id expect it lol
__________________
BREAKING MY ZETEC TURBO ESCORT!!!
MK1 Escort wanted!!!
rst in breaking is offline   Reply With Quote
Old 10-08-2009, 09:38 PM   #16
NUTS RuS
NUTS RuS's Avatar
Trader Score: (35)
NUTS RuS is an unknown quantity at this point
Send a message via Skype™ to NUTS RuS
Do you have the rear load valves still on ?
NUTS RuS is offline   Reply With Quote
Old 10-08-2009, 10:15 PM   #17
JamboRS
focus rs 1672
Trader Score: (0)
Quote:
nothing as std,its when its being asked to shift more fluid with 4 pots and rear discs that they cant cope
the fact u cant even talk proper leads me to dismiss anythin u say,rear discs are not dangerous,FACT,numnuts that put rear discs then dont get them set up,either using bias valve or compensators are dangerous,im included in this as i done the slame,so through my mistake i learnt,thgats called experience in my book,u can set a bias valve up for wet and dry conditions or as most do compromise in between,but thats not proper set up as ur not gettin the most out them in wet/dry conditions
check this thread a while back,more to setting up brakes than what u think
http://passionford.com/forum/ford-es...al-set-up.html
Old 10-08-2009, 10:56 PM   #18
vroooom ptssssh
It Wasnt Me!
Trader Score: (0)
Which reminds me, before I start using my car, I NEED to REMEMBER and set up the bias valve
__________________
My S1Resto
Old 10-08-2009, 11:54 PM   #19
NUTS RuS
NUTS RuS's Avatar
Trader Score: (35)
And remember a bias valve wont ever adjust bias.
All it does is increase or reduce pressure.
To shift bias you need a bias pedal box.
Old 11-08-2009, 12:25 AM   #20
makaveli96
makaveli96's Avatar
Trader Score: (0)
makaveli96 is an unknown quantity at this point
Hi, I’m looking to do a rear brake disc conversion soon I’ve almost bought everything needed but my question is will my rear brake compensator valves which were fitted last year so are near enough brand new be ok to adjust the rears?
__________________
186bhp with 205ft at 15psi
Italy World Cup Winners 34* 38* 82* 06*
makaveli96 is offline   Reply With Quote
Old 11-08-2009, 12:39 AM   #21
orion_crazy_carl
orion=mini saff
Trader Score: (3)
talk proper guv init
numb nuts is 2 words!its compensator's
anything has a G on the end, dont should be spelt like don't , so dont say i cant write proper dude
__________________
Old 11-08-2009, 11:18 AM   #22
Antti O
Antti O's Avatar
Trader Score: (0)
So i have to rebuilt brake lines because those are original diagonal. So i will buy one brake bias adjuster and set of new brake lines.
I comment when i have done that.
__________________
Old 11-08-2009, 12:06 PM   #23
JamboRS
focus rs 1672
Trader Score: (0)
least u understood mine
did i say write???i says talk
so no follow up to the dribble u wrote,thats ur best,carry on
Old 11-08-2009, 12:46 PM   #24
xr2wishy
Trader Score: (2)
xr2wishy is an unknown quantity at this point
personally i'd just buy new adjustable bias valves and adjust till you've got it right.
xr2wishy is offline   Reply With Quote
Old 11-08-2009, 04:16 PM   #25
orion_crazy_carl
orion=mini saff
Trader Score: (3)
only just
what master cylinder can you use then?there's no direct replacement is there?
__________________
Old 11-08-2009, 09:34 PM   #26
morph
morph's Avatar
Trader Score: (1)
only just
I cant see why you would need to go down the route of changing master cylinders to get the braking on the back right? that just doesn't make sense, when there are other easier methods!
Old 11-08-2009, 11:30 PM   #27
JamboRS
focus rs 1672
Trader Score: (0)
only just
Quote:
there was 2 parts to that,highlighted below
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv vvvvvv
the std master cylinder is shit with 4pots AND rear discs
out of interest what master cylinder does a 2wd cossie have in comparison to an rst ?????
Old 12-08-2009, 02:09 AM   #28
NUTS RuS
NUTS RuS's Avatar
Trader Score: (35)
22.2mm bore master on the cossie
23.8mm bore master on the RST
The larger bore will shift more fluid than the smaller bore
The smaller bore will give you a stiffer pedal, but wont actually brake any better.
HTH
Old 12-08-2009, 07:08 AM   #29
JesseT
Trader Score: (0)
JesseT is an unknown quantity at this point
Quote:
HTH
You probably meant lighter.
__________________
Orion tic & Escort tic & 2xFocus
JesseT is offline   Reply With Quote
Old 12-08-2009, 09:49 AM   #30
NUTS RuS
NUTS RuS's Avatar
Trader Score: (35)
No I meant what I typed
Old 12-08-2009, 09:02 PM   #31
morph
morph's Avatar
Trader Score: (1)
I have 4pots with cossie rear discs and the setup is able to stop my car just like i want to and i can't see how the master cylinder is shit with them?
so what are you advising everyone to run?
Old 13-08-2009, 01:40 PM   #32
S2Dan
Trader Score: (0)
S2Dan is an unknown quantity at this point
Send a message via MSN to S2Dan
The plan for mine was, if this will help, was to fit cossie stuff front and back. Losing the ABS and the rear compensators. And then to control and balance of the flow to the rears, use a bias valve on the rears, so effectively just having a permanent fixed pressure to the rears, rather then using weight varying compensators.
The secret to good braking with the rear disc conversion is balance. In my opinion the best way of achieving the balance on the rears is by means of a bias valve. As it’s a quick solution, although would recommend improved breaks up the front.
I think initial problems occur with the rear disk conversation if no attention is made to the fronts. As just fitting rears dicks without improving the fronts, will instantly increase the breaking percentage more then required before you’ve even started.
As for your problem of it pulling when breaking, check the calipers, just to make sure one aint sticking or some thing.
Good luck mate, and don’t be put off by the haters, they fear what they don’t understand.
__________________
S2Dan is offline   Reply With Quote
Old 13-08-2009, 02:42 PM   #33
JamboRS
focus rs 1672
Trader Score: (0)
im not advising anything,im merely stating that a master cyl designed to run single pots fronts and rear drums is shit when running 4 pots and discs,a completely new braking system which the std master cyl was made for
Old 13-08-2009, 04:42 PM   #34
Rick
Trader Score: (0)
Rick is an unknown quantity at this point
Send a message via MSN to Rick
Not if the 4 pot capacity doesn't differ greatly from the single pot on there now.
__________________
Bespoke calibration and remapping, OEM & Aftermarket management
Rick is offline   Reply With Quote
Old 13-08-2009, 07:28 PM   #35
Antti O
Antti O's Avatar
Trader Score: (0)
Problem sorted now, just had to reduce rear braking power.
__________________
Old 13-08-2009, 10:22 PM   #36
Rick
Trader Score: (0)
and how did you do that?
__________________
Old 14-08-2009, 06:00 AM   #37
Antti O
Antti O's Avatar
Trader Score: (0)
Adjusted original bias valves in rear axle. Last night i drive it lot and it is fine&safe now but there is no so much braking power as earlier so i may next spring buy proper bias valve and make new brake lines to correct that.
__________________
Old 14-08-2009, 11:22 AM   #38
JesseT
Trader Score: (0)
Could you please explain the reason, as this is on my mind completely against physics.
__________________
Old 14-08-2009, 05:01 PM   #39
Rick
Trader Score: (0)
Well first you need to define stiffer!Does it mean you have to press the pedal harder/with more force to stop the car, or does it mean that the pedal requires more force to move it a certain travel?!
__________________
Old 11-08-2010, 12:29 PM   #40
Antti O
Antti O's Avatar
Trader Score: (0)
Another year and same problem. I wish i never got into rear discs.
Now i have one brake circuit for fronts and one for rears and in the rear circuit there is wilwood valve with 59% max reducing going.
I have been thinking to replace stock rs turbo front cylinders with sierra cosworth 4 pot if that can help. I know those calibers are not cheap and not so easy to find.. but that rear brakes overpower drives me crazy and car is dangerous.
Now i have couple of questions:
1) Where i can get some cad pictures about those front brackets or who sells brackets?
2) Or is it better option to reduce rear brake disc size 273mm-> 253mm
ps.
If you read this and still plan to do rear disc conversion instead of working drums, DONT DO THAT.
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
3dr pulls to right (braking) windy miller Technical help Q & A 2 14-07-2009 09:08 AM
RST rear disc conversion questions Mr S1 General Car Related Discussion. 17 03-05-2008 03:36 PM
Rst Rear Brake Lines 4 Disc Conversion miller318i Ford Escort RS Turbo 4 01-05-2008 09:33 PM
S2 RST - Rear Disc Conversion. adamS2RST General Car Related Discussion. 6 14-02-2005 11:06 AM
rear disc conversion question RST trev1976 General Car Related Discussion. 5 27-11-2004 11:40 AM
