| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#201 | ||||
Balls Deep!
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk Last edited by Karlos G; 20-03-2010 at 06:17 PM. |
#202 |
as i said, still remapping car after altering fuel pressure a little, really sent the whole thing out loads.
it is a rough map as i only started working on it a couple of runs earlier but had to use it so switched ego correction on. idle advance was turned up a tad the other day as it keeps bogging down on 0-light throttle at first, really leans out on the first bit of accelerator. |
#203 |
you tried the fuel cut of to help out
__________________
#204 | |
Balls Deep!
Quote:
If it leans out on the first bit of accelerator and 'hangs' for a second then you need to adjust the Accel Enrichment until it doesnt do it, when the throttle body opens the engine takes a big gulp of air and the you need to give it a bit more fuel briefly to compensate.
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk |
#205 |
#206 |
Just read all this thread its quite intresting wouldnt mind having ago at it my self. Do you get instructions with the kit and whitch is the best one to get? Also do you have to sort out your own base map or can you get them off the net somewhere?
__________________
#207 |
Balls Deep!
If you buy from www.extraefi.co.uk then yes there is instructions for fitting, setting up, even basic mapping principles.
Also they will supply you with a base map that should be close enough to get your car started, or there are a few of us on here that can sort you one out
__________________
#208 |
Thanks karlos will you be at central day so i can pop over and have a look at your car?
__________________
#209 |
Balls Deep!
Not sure yet mate, if i'm ran in and reliable then I might pop down for the day!
Having just built the engine, fitted a new gearbox, LSD, Hydraulic clutch, and quick rack there is still plenty of time for teething problems... Like my alternator chewing through my bottom rad Samco!
__________________
#210 |
Haha countdown to boost. I remember that stage of my engine. It was rubbish!
__________________
#211 | |
Quote:
The MS3 also gives you a starting point for even more expansion. You will be able to connect the pin headers on this board to additional hardware, such as the MS3X board (not yet released) or other cards to enable features like these: * 8 channels sequential fuel control * 8 channel sequential ignition control * Individual fuel and spark trim for cylinder by cylinder tuning * 2 and 3 channel PWM IAC control * 2 stage nitrous controller * Table switching for multi-fuel engines * 2 step launch control * And more!
#212 |
And i've been lucky enough to have onse since last year
__________________
Bespoke calibration and remapping, OEM & Aftermarket management
#213 |
/\ git!
mine will have to wait as i'm skint, so ms2 for now. i so want sequential injection to make it more efficient and time the squirts perfectly. |
#214 |
You don't need MS3 for sequential, MS2 will do it fine, you just need to add some injector drivers. One of these is ideal:
http://www.jbperf.com/p&h_board/v2_0.html It's a proper peak and hold 4 channel driver module. Or you could use the v1.1 board which sits inside the original MS case. Rick
__________________
#215 |
Is MS easy to map? The amout on load sites makes it look pretty easy as there isn't much to do.
This is a spark table out of my ECU for comparison. The fuel table has just as many load sites.
#216 |
Balls Deep!
Fuck me that is a lot of load sites!!!
lolWhat management is it Daz?
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk Last edited by Karlos G; 27-03-2010 at 12:39 AM. |
#217 |
Life Racing F88RS. Thats been reduced by about 6 load sites along the rpm axis as well. There is obviously correction tables on top of that and there is just as many for the fuel table too.
I assume that the MS is relatively easy to map in comparrison with having less load sites. |
#218 |
Just had a dyno-day yesterday. 1.8zvh 235whp /torque 342nm.
Running on MS-1. AFR was not on its best- 11,5 on full boost (1,1bar). Some horses went there. |
#219 | ||
Balls Deep!
Quote:
Quote:
![]() 11.5:1 isnt that far off what it should be 11.8:1 doubt you will have lost much fella. Post your graph and spec up mate be interested to see how and where it makes power!
__________________
#220 |
MS tables are fully interpolated using least squares method. More is not better in this case.
__________________
#221 |
fookin 'ell Daz, that is a load of variables to be entered in there.
MS is easy in comparrison and even on the MS3 which could have handled more that 16x16, there was little point making it any bigger really. i'd quite happily show you how easy it is anytime pal. p.s. Karlos, done a bit of mapping and we're running sweet now, never really get chance to do any these days, so ends up shite like my last session did. alls good now and have turned EGO off as it was ruining running if i switched off after a run then started up a minute later as the wideband has to enter warmup mode and sends erroneous data to ecu till it's up to temp. |
#222 | |
Quote:
With slipping stock clutch. Thats why there is spike on the graph. One of my friends gained 50php with this correction, increasing AFR 11,...- up to 13,.... http://www.youtube.com/user/MTechVid.../0/jLWX-FCJdVs
#223 | |
Balls Deep!
Quote:
No mate thats far too lean for a RST!! 12.5:1 will make good power but without monitoring it for detonation it's too close to a meltdown. IMO 13.5:1 is ridiculous for a forced induction engine, it will run way to hot and you'll have to retard the timing massively to stop Det.
__________________
#224 | |
Quote:
#225 |
Balls Deep!
It will make power for sure but how long will the engine last?
I supose if there is not Det and the EGT's are not too high then it's ok...... just seems way to lean to me! The extra 100bhp can be down to many things... Turbo, port work, valve size, cam, valve timing, ignition timing, CR, ACT's, manifolds, etc..etc...
__________________
#226 |
nowt wrong with running higher afr's, however peak torque is around 13.5 and peak horsepower is around 12.5.
running too lean for too long will make things get a little too hot for sure, too rich and you sacrifice power for safety. basically you want it as lean as you can get without DET and EGT's getting too high. the extra richness keeps the cylinders and pistons cooler, all engines pretty much have similar tolerances to heat and an rst is no different. i have run on boost at 12.5 without problems, but retarding ignition is needed to do this safely. with careful monitoring you can get it as lean as you like safely, just start rich and lean out as it's much safer to do this. |
#227 |
p.s. a 2.1 zvh has more capacity than a smaller engine, i know of a 1.8zvh pushing nigh on 370bhp, mine is around 300bhp with little work apart from a good bit of porting and a 4wd cossie turbo.
#228 |
Not a chance I would run any forced fed engine that lean. Even a naturally aspirated engine I'd be aiming around 12.5......
#229 |
Balls Deep!
I have maxed them out on my engine running 18psi @ 7000rpm, the injector duty is at 95%! Although they were fuelling ok at 106% it's too risky that one or more cylinders might be lean so I have had to turn my boost down!
__________________
#230 | |
YES I KNOW I CANT SPELL
Quote:
maby i should upgrade injectors as well
__________________
" im special,, excuse my spellings" |
#231 |
Balls Deep!
Errr... yeah might be a good idea! lol
__________________
#232 |
my injectors are 440cc and i thnk i'm near the limit at 20psi on 6.5krpm on my 1.8zvh.
looking for bigger ones already. |
#233 |
Mine are about 640cc and have plenty of duration left. Even at 2 bar of boost on a GT2871R.
#234 |
__________________
#235 |
Balls Deep!
Well maybe they will be ok then, I would of thought a bigger engine would need more fuel than a smaller one as it flows a lot more air?!
__________________
#236 |
hummm i gess ill have to see
__________________
#237 | |
Quote:
i was thinking about it on the way into what fuel pump are you useing? do you think maby your presure is droping off? my mates st turbo has gone to totd for mapping this week hes running 440's and they seem to think they will be fine with his gt30 and hes looking for around 320hp
__________________
#238 |
It's because the BSFC on an 8v CVH is much higher than on a multivalve engine. You'll struggle to get 300 out of 440's on a CVH.
Don't forget the ST has 5 of them so 330 is no problem.
__________________
#239 |
Balls Deep!
For anyone that didnt know (including me) what BSFC is...
It's the ratio of an engines fuel consumption to an engines power output as measured at the flywheel. BSFC has units of grams of fuel per kilowatt-hour (g/kWh) or pounds mass of fuel per brake horsepower-hour (lb/bhp-hr). BSFC is a measure of engine efficiency! So basically the little CVH is not very efficient and needs a lot more fuel to make the same power as an engine with a lower BSFC
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk Last edited by Karlos G; 14-04-2010 at 04:35 PM. |
#240 |
How have you all learned how to map ms? I have rebuilt my engine, car , painted it everything realy so I'd like to map it myself to.
How hard is it to get the map to a "safe" standard? Btw carlos loving your work, very interesting top job
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| rsi cabbie,pics efi xr3i to efi turbo | rickbartlett | Pictures, video & Photoshop Forum | 8 | 24-06-2009 11:12 PM |
| F**k it! I'm going EFI and Megasquirt!! | Karlos G | Ford Escort RS Turbo | 94 | 16-06-2009 03:46 PM |
| Megasquirt+CVH EFI and IACT valve. Idle problems | Antti O | Technical help Q & A | 3 | 11-03-2009 09:27 PM |
| efi conversion......efi cps hole block tracing wanted please | Moondust_crust | Ford Escort RS Turbo | 36 | 30-11-2008 10:57 PM |
| pacet fans 11", efi manifold, efi head, ecu, loads more | B16 WLD | Ford RS Turbo parts for sale | 4 | 18-03-2007 03:53 PM |
