PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Turbo
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 04-07-2009, 06:22 PM   #1
white2lsr
white2lsr's Avatar
Trader Score: (1)
white2lsr is on a distinguished road
Default XR3i Block?
Could I use an XR3i block to rebuild my rsturbo engine still running MFi? Obviously the turbo oil return would need to be sorted but surely that wouldnt be a problem???
white2lsr is offline   Reply With Quote
Old 04-07-2009, 06:58 PM   #2
studabear
studabear's Avatar
Trader Score: (0)
studabear is on a distinguished road
don't see why not
__________________
Megasquirt project underway, hope my clutch can stand 20psi of boost
studabear is offline   Reply With Quote
Old 04-07-2009, 08:01 PM   #3
cabrst
Trader Score: (0)
cabrst is an unknown quantity at this point
Send a message via MSN to cabrst
yes you can, as you say only oil return are diffrent
__________________
see pic: http://www.escortrsturbo.co.uk/forum...9081&st=320yes i know, im danish!!! sorry
cabrst is offline   Reply With Quote
Old 04-07-2009, 08:18 PM   #4
white2lsr
white2lsr's Avatar
Trader Score: (1)
So the MFi head will go on no problem, no issues with oil/water galleries not lining up??
Old 04-07-2009, 10:16 PM   #5
XR2
Insane Bavarian
XR2's Avatar
Trader Score: (0)
XR2 is an unknown quantity at this point
Heads were all the same and oil and water galleries also. The only differences were - as mentioned - oil return
XR2 is offline   Reply With Quote
Old 04-07-2009, 10:18 PM   #6
white2lsr
white2lsr's Avatar
Trader Score: (1)
Time to look for a low milage CVH engine to rob of its block. I think it is going to be a good plan as a lot of turbo blocks are needing re-bored these days and I really dont want to go down those lines!
Old 04-07-2009, 10:20 PM   #7
XR2
Insane Bavarian
XR2's Avatar
Trader Score: (0)
Piston height of a turbo is different to the XR3i items...
Get new oversized turbo pistons and rebore your block. Believe me, you'll regret it not...
Old 04-07-2009, 10:22 PM   #8
white2lsr
white2lsr's Avatar
Trader Score: (1)
Quote:
hence why ill only be using the block, i have good internals
Old 04-07-2009, 11:55 PM   #9
xr2wishy
Trader Score: (2)
xr2wishy is an unknown quantity at this point
done the same myself once, only oil return needed.
xr2wishy is offline   Reply With Quote
Old 05-07-2009, 04:03 AM   #10
nzwhiteboy
Trader Score: (0)
nzwhiteboy is on a distinguished road
where abouts would u put the oil return? ive got a xr3i block here and a RS block but at the moment its a mission to find a RS block in New Zealand and i cant afford to rebuild it just yet so im going to use an xr3i block for a few months
nzwhiteboy is offline   Reply With Quote
Old 05-07-2009, 05:05 AM   #11
kev new
Trader Score: (1)
Location: Trailer trash in Oman desert, its good honest Guv!
kev new is an unknown quantity at this point
Quote:
pretty sure there is a square bit on cast of block that requires drilling and inserting a drain tube prob araldite it in there.....been told its easy to do by an engine builder.
but if anybody remembers the turbo technics rs16I conversion the sumps were modified to take an oil drain instead of doing the block.
kev new is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
200 Block & 205 Block Mike C General Car Related Discussion. 38 23-03-2008 04:46 PM
The difference between a 205 block and a 500 block rizla Ford Sierra / Sapphire / RS500 Cosworth 10 05-11-2007 08:23 PM
2ltr zvh block / fiesta RST block JimmyBoy Cars & Parts Wanted. 1 07-03-2007 08:59 AM
can i fit 200 block internals into a 205 block ?? Ginge ! General Car Related Discussion. 11 06-08-2005 11:06 PM
4wd block and 200 block whats the difference ? xfactor General Car Related Discussion. 4 27-10-2004 03:33 PM
