PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Ford Escort RS Turbo
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 16-06-2009, 01:15 PM   #1
kidsRS
"Ill check the stock"
kidsRS's Avatar
Trader Score: (6)
kidsRS is on a distinguished road
Default How do you disconnect a immobiliser
I have just bought a xr3 cabriolet the previous owner said there is something wrong with the immobiliser thats why it wont even turn over how do i disconnect it?
kidsRS is offline   Reply With Quote
Old 16-06-2009, 01:23 PM   #2
daviddunlop83
daviddunlop83's Avatar
Trader Score: (6)
daviddunlop83 is an unknown quantity at this point
Quote:
It would depend on what immobilsier is fitted. I know some of the old clifford ones basically all they did want cut the wires to the ignition barrel and by pass this throught the immobiliser so all you needed to do was cut the wires off and join the original ones back up.
But there is so many different types and ways of immoblising the car.
daviddunlop83 is offline   Reply With Quote
Old 16-06-2009, 01:25 PM   #3
kidsRS
kidsRS's Avatar
Trader Score: (6)
Iv just been looking can i simply disconnect all the wires?
Old 16-06-2009, 01:29 PM   #4
daviddunlop83
Trader Score: (6)
Are the wires coming from the igniton barrel cut and by pased through the alarm? If so they cut all the alarm wires off and join the ford ones back up and it should work. Or before you cut it use another piece of wire and join then up just temporary to see if it will work.
Old 16-06-2009, 01:33 PM   #5
kidsRS
kidsRS's Avatar
Trader Score: (6)
The ford wires arent cut 2 extra wires from my immobiliser box are soldered to the ignition barrel and maybe 2 more wires coming from the box and going into the loom under the dash
Old 16-06-2009, 01:36 PM   #6
daviddunlop83
Trader Score: (6)
I think if you follow the other 2 wires from the box there may be a wire that is cut and they go onto either side of it.
If that is the case join it back up and cut the ones from the alarm off.
The two coming from the ignition barrel might be power for the alarm maybe?
Old 16-06-2009, 02:32 PM   #7
kidsRS
kidsRS's Avatar
Trader Score: (6)
Iv just ripped the box and wiring out i now have it turning over but the fuel pump doesnt seem to be running?
Old 16-06-2009, 04:37 PM   #8
kidsRS
kidsRS's Avatar
Trader Score: (6)
Shes up and running!
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Fuel rail disconnect captiva Ford Sierra / Sapphire / RS500 Cosworth 2 09-11-2007 01:23 PM
Wireless Router Disconnect problem. Tangodeltasierra3 Computers, Consoles and I.T. 7 18-06-2007 11:17 PM
4x4 cossie knock sensor, disconnect it???? Dean Saff Technical help Q & A 1 02-04-2007 04:44 PM
IS IT POSSIBLE TO DISCONNECT THE FORD ALARM D7AKE General Car Related Discussion. 8 01-10-2006 07:03 PM
How do i disconnect my ABS and is it reccomended? rog Technical help Q & A 5 10-06-2006 07:14 PM
