| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#41 | ||||
__________________
#42 | |
Quote:
#43 |
I read your thread on boost pressure. That was a bit of a debate! Is your car basically all sorted out now? Regards to the inlet i.e decent head, decent intercooler. The manifold in the middle is not allowing the head and intercooler to do their job properly. Can you see what i mean? Get the inlet sorted out so you have got a decent flow to head. If you can get hold of a series 1 inlet manifold, even better.
__________________
#44 |
My project has taken a standstill at present due to an issue with the metering unit deciding to pack up and chuck fuel into the lower boost pipe.... so until i finally get round to collecting my replacement, everything is on hold. I will look into getting the inlet flowed and Im guessing too, the bit between the head and inlet manifold (cant recall name of it). The head, as far as im aware has had some work down to it as the holes all looked fairly larger than the last head and were very smooth on the inside... but i aint believing nothing until i get it all checked over properly.
As for my Boost Thread Yea, it did go into a little debate stylee. Whatever tho, loads of ZVH's have been created over the past, and will still in the future... Mentioned above, its a budget engine that can produce great power and gives piece of mind knowing newer parts are being used... not starting a debate here now tho guys ok, so dont shoot me down!!!
__________________
#45 |
marts
Reduilding the meter unit then.
__________________
#46 |
I got told that there's not much to the metering unit as it is. All mechanical bits are sensors and the only moveable parts etc were the plunger and flap. Mine seems to be leaking fuel from the distributor on top to the air box below.... also told of an O-Ring that sits between the two, but talking with ford, and gaining an exploded diagram shows otherwise. I think its just fooked!
__________________
#47 |
Zetec turbo for me all the way, so simple, a simple buid using c20let psistons uprated valve springs and use arp rod bolts with rs1800 inlet and keepz it simple and less involed in my opinion
#48 |
chatter 4 life
matt zetec head is good for 300bhp, all my mates have has close to 250bhp from just fiting a 1mm decomplate. i have gonna for a 2.5mm plate and dare say i could push 250bhp spot on np, zvh are good but a zetec turbo wins hands down.
zvh will run spot on runing mfi no need to go efi.
__________________
check out the mk3 zetec turbo build http://passionford.com/forum/restorations-rebuilds-and-projects/182173-mk3-escort-2-litre-zt-28-3-2010-geting-pissed-off-now-still-no-spark.html Member of "The Daytime pf talk bollocks and random shite club #110 www.stocktonautocentre.com |
#49 | |
Quote:
Dont suppose you have the R/R graph to show do you? not disputing it at all, just interested to see the power/torque curves
__________________
![]() Mac Motorsports Worx ZX10r turbo engined kit car... build thread in the restorations, rebuild & projects section PS3 username - SausageArm ....... My DSLR photo's - http://www.flickr.com/photos/30990332@N02/ |
#50 |
zetec turbo for sure in my opinion, c20let pistons, small ends machined and arps along with uprated valve springs will see 300bhp (ok rods are on thier limits but same would apply for zvh)
__________________
![]() BREAKING MY ZETEC TURBO ESCORT!!! MK1 Escort wanted!!! |
#51 |
i never had any trouble with my old zvh over the years
__________________
![]() More chatter than your mum in bed www.fordrsparts.com www.area-six.co.uk www.grovegarage.com www.proalloy.co.uk |
#52 |
__________________
#53 |
mums the word lol black one is at my work about to gointo the body shop turbo is at cr turbos and grove have my engine
__________________
#54 |
i supose theres good points and bad about both conversions,different ways of getting good reliable power, but dont see the point in mating two engines together,and seems to be more hassle to build,everyone has there own way and not to forget budget
#55 |
Insane Bavarian
In earlier days there sure were some good reasons to build a ZVH engine. You got reliable capacity AND you were able to use existing injection systems (ERST, FRST) that fit plug&play to the cylinder head.
Nowadays many people in search for a maximum increase of power use mappable injection systems. So why dropping 8 valves (nearly all high power engine in modern cars use 4 valves for each cylinder) AND using a head thats already antique? That's my opinion... Use engine capacity up to 2000 ccm AND a 16V cylinder head AND a mappable injection. |
#56 |
Trader Score: (0)
Rep Power: 6 ![]() |
I think I have builed good Zvh engine, but as an upgrade I will builed full zetec now.
__________________
Anything that doesn't kill you, makes you stronger.... 1.6 CVH RST turbo on MFI 1/4 mile in 13.93 sec 2.1 Zvh on MS 12.39 2.1 Zetec turbo on MS 11.81 |
#57 |
Bodybuilding
Trader Score: (0)
Location: Cannot be identified by the information given.
Rep Power: 8 ![]() |
zetec turbo's are also overrated without spending a lot of money
take a look at this graph below 2.1 zetec turbo area six ported standard valve head T38 turbo high lift cams power only just holds on after 5.5k
#58 |
#59 |
i wouldnt say overated,you can get far more power for alot less outlay,and that gets my vote
#60 |
i built a zvh in my fiesta rs, standard head, piper cam and pully, standard t3 turbo, scorpion exhaust, front mount intercooler, cossie fuel pump, beige injectors, and 19psi of boost on ofac managment, pulled in 228.1 bhp with 221.4 lb torque
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| n/a ZVH or n/a Zetec | ben16i | General Car Related Discussion. | 16 | 20-02-2009 10:52 PM |
| CR ZVH-> Zetec | Gregor | Ford Escort RS Turbo | 16 | 06-08-2008 02:54 PM |
| ZVH? or just ZETEC? | lickshot | General Car Related Discussion. | 11 | 27-11-2006 12:16 AM |
| ZVH or ZETEC T | cossiegreg1 | General Car Related Discussion. | 2 | 25-07-2006 09:19 PM |
| FAO zetec turbo/ZVH peeps: Turboing a zetec advice please | Anonymous | Technical help Q & A | 0 | 25-11-2003 09:37 AM |
