What do I need to convert my MFi RS Turbo to run EFi? Updated 05/04/14
Old 15-04-2012, 04:22 PM
  #81
logitech
logitech's Avatar
hi does anyone know how i can identify that the loom i have bought is a fiesta rs turbo loom the part number on the loom is 90-fg14014-cb much apreciated
Old 22-04-2012, 01:39 PM
  #82
Cameron
Cameron's Avatar
Pin 6 goes to the oil pressure switch instead of the original mfi wiring for the pressure switch? Dont get how that would be connected to the light on the dash?
Old 25-04-2012, 08:22 PM
  #83
Cameron
Cameron's Avatar
Can anyone help me here ive wired it up as per the diagram, but now have no battery or oil pressure light when i switch the ignition on, is this right? also do i wire pin 6 to the oil pressure switch aswell as the original mfi wiring from pressure switch to instrument panel?
Also can the Amal valve from the escort still be used? or is it wired into the old mfi ecu? i presume you can just blank the outlet off that went to the metering unit?
Old 07-05-2012, 07:58 PM
  #84
martinmilne
martinmilne's Avatar
done the efi conversion on my cab ofac with full efi loom but not gettin a reading on rev counter any ideas its efi clocks
Old 08-05-2012, 11:26 AM
  #85
Dennis_Wiseman
Dennis_Wiseman's Avatar
Do mk4 Escorts have a seperate engine to car multi-plug or are they hard wired in?
Basically do you have to wire things up car side (as per 1st wiring diagram page one) to a female multi-plug so it fits into the ofab engine loom plug?
Old 08-05-2012, 12:30 PM
  #86
mentalasanything
mentalasanything's Avatar
I can't remember where the rev counter is fed from on a full EFI loom with EFI clocks, I believe it's fed from one of the coil outputs. Trace the green cable from the back of the clocks to ensure there are no breaks. Alternatively, pin 11 of the EDIS4 module is a Clean Tach Output, this can be used on standard clocks.
MK4 Escort looms are all one piece looms. You will have to remove the tape and cut out the engine loom sections and add a female multiplug to take the FRST loom. Alternatively after cutting out the engine loom, hard wire the FRST loom in its place.
Lee
Old 08-05-2012, 12:38 PM
  #87
Dennis_Wiseman
Cheers mate.
Do you know if female Zetec multi-plugs are compatible with the male OFAB one? or will it need to be a FRST one?
Old 01-06-2012, 03:02 PM
  #88
stafcio
stafcio's Avatar
should there be any voltage (1,5V) coming out of pin 5 & 6 on edis to CPS?
Old 05-06-2012, 04:52 AM
  #89
stafcio
stafcio's Avatar
i found it my self. there should be 1,5V
if you're doing conversion make sure pins to cps are correct.
my mfi to efi is success.
Old 17-06-2012, 07:56 PM
  #90
beaver rs 88
in the garage
beaver rs 88's Avatar
when converting using the frst loom where do you put the fuel relays? behind the dash or in the engine bay?
Old 18-06-2012, 09:49 PM
  #91
mentalasanything
Anywhere you like. You might as well put them behind the dash though.
Lee
Old 23-06-2012, 09:42 AM
  #92
zxevhbonus
old school
zxevhbonus's Avatar
hi to start with this is a great thread now i have just got a xr3i efi loom to run my 2.1 zvh escort bonus now when i got the loom the fella said it was running ofab but i have had a look at the loom and no pin canges have been made the only thing i can find is that a brown wire near the inlet manifold is cut the fella i got it from said if you connect it the car will not run dose this make any sence would ofab run it because this wire is cut
Old 07-09-2012, 04:27 PM
  #93
T555DAN
T555DAN's Avatar
Sorry if this has already been asked but if I bought an EFI xr3i would I have all the parts required to do the conversion
Old 03-11-2012, 08:04 AM
  #94
Volkov
Volkov's Avatar
Hi!
Is there anybody, who's car is working NORMALY with the publicated OFAC (0FAC) pinouts?
I've done everything step-by-step. Checked 100x times, but the car always had error code 59: CO potentiometer error. (poor or no idle, etc)
It was usable, and powerfull, but sometimes it was very anoying.
After 2 years s@&#ing it's clear why!
The "27, Brown – CO adjust potentiometer" it's realy pin8 on OFAC to!!!
So the 1AFA and OFAC (0FAC) are NOT the same!
Changed that pin, and all my problems gone!
Fault code reading: code 11= Full system pass.
Got fix 950 rpm idle!
Cheers,
Andras
Old 13-11-2012, 08:14 PM
  #95
Mrparry1984
Mrparry1984's Avatar
Ok I know this is a Mfi to efi, but I'm putting a frst engine into a mk3 which was a 1.3, I've bought a full loom including ofab ecu but do I have to change my clocks and or my original loom?
I'm not fussed about a rev counter as I want it to look 1300 inside. But will it still work if I just use the engine/ignition, and fuel sections.
Don't get me wrong I know it's not gonna be the easiest thing but I'd rather know what extent I need to undergo.
Thanks lee
Old 15-11-2012, 07:54 PM
  #96
stafcio
stafcio's Avatar
when installing ACT from FRST should i use the same wires that are in act mfi plug? when engine is running and i unplug it, revs go down is it correct?
Old 15-01-2013, 03:46 PM
  #97
chalkey
rst junkie
chalkey's Avatar
where do all you guys mount the ecu on your conversions? im just about to convert to ofab
Old 15-01-2013, 06:28 PM
  #98
fsteward
fsteward's Avatar
i have ofab loom ecu and map sesor and edis4 im not useing !!!!
Old 16-01-2013, 09:52 AM
  #99
chalkey
rst junkie
chalkey's Avatar
hi bud
im only missing the map sensor and co pot now
Old 05-05-2013, 12:16 PM
  #100
mentalasanything
Afternoon all!
It's been 4 years since I wrote this thread and today I finally got it running!
It didn't go without a hitch so I will update the original post with all of the troubleshooting steps. But the end of the tunnel is now in sight!
Cheers,
Lee
Old 07-05-2013, 07:13 PM
  #101
stafcio
stafcio's Avatar
wow, 4 years. nice result
i still have some fuel issues, but i'll wait until you update the thread.
Old 17-07-2013, 08:20 PM
  #102
mentalasanything
Updated today with pin changes required on some looms
Lee
Old 16-08-2013, 08:19 AM
  #103
mentalasanything
Edited to update: Pin 11 of the EDIS (CTO) didn't work with my rev counter. I've had to use the diode circuit.
Lee
Old 18-09-2013, 11:33 AM
  #104
Dennis_Wiseman
Where do you mount the ECU as it won't stretch to inside the car ?
Old 19-09-2013, 07:36 PM
  #105
mentalasanything
I'm not sure where people mount it when using the Fiesta loom but using the '3i loom it goes behind the centre console under the radio.
Lee
Old 20-09-2013, 10:59 PM
  #106
Dennis_Wiseman
Yeah i managed to get a 3i ecu bracket expecting to mount the Fiesta ecu inside the car but when the Fiesta loom arrived, no chance lol
Anyone know?
Old 07-10-2013, 06:05 AM
  #107
Turbo Al
Turbo Al's Avatar
this may sound silly but on rabs diagram he has the engine plug showing wires going to 8 pins, is that the ecu plug he is talking about? if so is it the first 8 pins?
i have full frst ofac loom
cheers
Old 14-10-2013, 08:11 AM
  #108
mentalasanything
cheers
Hello mate,
No, the 8 pins are the pins on the FRST engine loom connector not the ECU
Lee
Old 15-10-2013, 09:10 PM
  #109
marky_g
Fleet Manager
marky_g's Avatar
Brilliant loom advice I'm using a late spec 3i car and it just won't fire gonna check the pin location the weekend woohoo light at the end of the tunnel finally
Old 16-10-2013, 06:41 AM
  #110
stafcio
stafcio's Avatar
hello guys,
i am after all the conversion. everything is working but i'm not sure if correctly.
should i have some kind of a chip or stand alone mounted? T3 is bigger than standard T2 (ecu is from frst - 0fac). so it might blow more air and afr is lean. am i right? this can cause overheating.
did you check afr after this conversion?
is it possible to get afr right without any chip or SA?
Old 16-10-2013, 08:41 AM
  #111
marky_g
Fleet Manager
marky_g's Avatar
Would the pin changes that Karlos mention make the car not run at all?
Old 19-10-2013, 01:36 PM
  #112
Turbo Al
Turbo Al's Avatar
Ive probably read through and missed the answer to this question. Im using the frst loom and rabs diagram shows the 8 pin plug to wire to the car, the loom has a 8 pin plug with 8 wires just at the inlet manifold and a 8 pin plug with 7 wires which joins to the fiesta car loom which I would say goes to fuse box etc.
Am I right in saying I need to wire from this plug and add an aditional pin?
Old 19-10-2013, 09:00 PM
  #113
Turbo Al
Turbo Al's Avatar
Forget that, just looked at the diagram closer. My bad
Old 25-10-2013, 05:57 AM
  #114
Turbo Al
Turbo Al's Avatar
its alive
cheers for the info lads
Old 06-12-2013, 09:25 PM
  #115
mattxr2
mattxr2's Avatar
i was wondering if anyone could help me i have a mk2 fiesta which i have converted to efi turbo with 195 chip, cozzie map sensor, beige 701's, adjustable fuel pressure regulater 1mm oversize pistons ect ect... i wired it all in friday following a diagrom off this thread and now i can get any spark. i havent currently got a vehicle speed sensor on the car, is this why? i tested the powers to the coil pack and the middle is live and wire no1 + 3 are a pulsing live but i thought they should be a pulsing earth, im a little lost as its my first conversion as im only 19 and its my first car lmaoo i was wondering if anyone had a pic of what the vehicle speed sensor looks like and what could be chanching the pulsing earths to pulsing lives ??????
Old 08-12-2013, 07:54 AM
  #116
mentalasanything
Don't worry about the VSS, that won't cause it not to spark. IIRC those outer pins on the coil harness are live until they pulse to earth. When they're not live are they earthed?
Lee
Old 08-12-2013, 07:57 AM
  #117
mentalasanything
Originally Posted by Volkov
Hi!
Cheers,
Andras
Only just spotted this comment. Very unusual for OFAC to use pin 8 for the CO pot, in fact I've never heard of it. It's definitely 27 on mine.
Lee
Old 10-12-2013, 04:10 PM
  #118
mattxr2
mattxr2's Avatar
Lee
no mate they are just a pulsing live they dont earth at all apart from when the ignition is completely off
Old 16-12-2013, 09:00 PM
  #119
mentalasanything
I'd hazard a guess that you have a bad earth. They should alternate between live and earth.
Lee
Old 21-01-2014, 10:41 PM
  #120
beaver rs 88
in the garage
Do you need the vehicle speed sensor when you convert or do you leave it out?
Quick Reply: What do I need to convert my MFi RS Turbo to run EFi? Updated 05/04/14
