bonnet catch
bonnet catch
ive got bonnet raisers on my s2, and ws wonderin if there is anyway i can make the catch lock any better????
i want to keep the raisers on before any1 says take um off!!!!
If you take the catch (the part attatched to the bonnet) off and put some washers between the two surfaces, that should give the catch a little more 'reach'. I needed two washers, but my mate just needed one...
That's what i did anyway, takes a while as you have front to back and side to side adjustment on the catch as well, i marked the original position on the bonnet as a reference when re-fittting.
Hope this helps mate...
ok mate cheers ill have a look at that 2moro wen its light
i got mine from burton for about 12 quid .
there really easy to fit just bolt them down to where the rubber gromits go what hold your bonnet to the right height and put a bit of grease on top of them.
close the bonnet so u get grease on the bonet where they sit.
drill it fill it ..then screw them down ..its a really east jobs and only tkes couple of hours or so...theres no way my bonnet will pop up now
07-10-2015 12:56 PM
Adam Graham
06-09-2015 06:04 AM
