| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/restorations-rebuilds-and-projects/222915-zetec-turbo-on-megasquirt-new-turbo-arrived-gt2871r-p.html |
#2 |
#3 |
Colossal Pervert
Standard Ford ones are fine at 500bhp.. and a lot cheaper!
__________________
![]() Ban #1: 23/09/08-25/09/08 - Posting a photo of the Gestapo. |
#4 |
__________________
2.0 Zetec turbo on megasquirt --> 261,5 BHP and 291,3 lb/ft (395 nm) @ 16 psi http://passionford.com/forum/showthread.php?t=222915 |
#5 |
Colossal Pervert
Yes..
__________________
#6 |
Hmzz Would save me some cash i can spend on some other parts....
Are the standard headbolts used here or arp ones? thanks
__________________
#7 |
Colossal Pervert
Standard are fine
__________________
#8 |
great ,
Thanks again
__________________
#9 |
Put the cometic and standard Focus 2.0 gaskets side by side and you will not see much of a difference. Cometic has a wider selection of thicknesses though with Ford only having two to choose from.
#10 |
It's for a silvertop zetec but i guess i can use the focus one or is the mondeo gasket the same?
__________________
#11 |
Colossal Pervert
Just go with a Focus RS one..
__________________
#12 |
__________________
#13 |
orion=mini saff
![]() Trader Score: (3)
Rep Power: 12 ![]() |
focus RS one bud
#14 |
Lukesville
agreed focus Rs gasket is tried and tested
__________________
Built @ JKM Performance - NEW SPEC 471.9 bhp ![]() thetrolley +500hp/ton - 134mph over 1/4 mile April 2011 - 11.74 @ 129.15mph |
#15 |
cheers Guys,
Wil get me one asap
__________________
#16 |
orion=mini saff
mat lewis is doing ones on ebay,got mine for 20 quid
#17 |
__________________
#18 |
Colossal Pervert
About Ł30.
__________________
#19 |
Focus RS gasket is the same than the nonturbo engines use. Only the ST170 gasket is thicker with fourth steel layer.
#20 |
__________________
#21 |
#22 |
st170 is what you need
__________________
![]() More chatter than your mum in bed www.fordrsparts.com www.area-six.co.uk www.grovegarage.com www.proalloy.co.uk |
#23 |
go for the rs focus one for sure !!
st170 is thinner not thick as it is a high comp motor !!!
__________________
17" tsw reflexs bomz kit fast road cams/obx pulleys,underdrive pulley drop 30mm eibach springs blueflame catback exhaust 4.1 ceramic coated exhaust manifold custom down pipe/highflow cat 300mm disc conversion,st bodykit more to come to own another ford with a difference fancy something turbo |
#24 | ||
Quote:
Quote:
Wich one is stronger is more inportant or is strong enough for some reasonable boost ( minimum 21psi )
__________________
#25 |
i had an st170 headgasket on mine for 5 years never any trouble 22 psi
__________________
#26 |
It's very unconsiderate to make statements based on false assumptions. The difference in the compression rate is not made with the head gasket thickness. The ST170 gasket is on the order of 1.0mm and the other 2.0 gaskets, including RS, is on the order of 0.6mm thick. The thickness should be chosen so that the piston crown to cylinder head plane distance is optimum. Usually this is between 0.7-1.0mm depending on application. If you then end up with the wrong compression ratio, then you have an unsuitbale piston dish/dome volume.
#27 | |
Quote:
Thats why you can buy various thickness` of gaskets which makes up the "extra material" from having your head skimmed.
#28 | |
Quote:
Back to the point: The whole engine should be specced as a whole, including the gasket thickness. Extra care should be taken when mixing pre/post -95 or euro/us zetec parts. |
#29 |
I'll get the cvh head of first then and see how big pistoncrown to head distance is when i get either of the gaskets on.
__________________
#30 |
If you are running low comp they should be well clear anyway, its high comp engines where you tend to get the most problems.
Place sum plasticine or mouldable wax on the highest part of the piston (if they arent flat), smear a small amount of oil on the head chamber, place the H/Gskt on, drop the head on, nip up the headbolts slightly, rotate the engine thru 2 revolutions, whip the head back off,slice through the squashed wax/plasticine in sections and mic up the thickness, try not to pull it off too hard (oo er!) as it will stretch and become thinner. (do this for all 4 to be on the safe side) You are looking for around the 1mm mark, this allows for heat expansion and rod stretch at high rpm Good Luck! ![]() Oh...just to add, if you think the valves may come into contact, its the same principle but you will obviously need to put the cambelt on etc.... (solid followers would also be advisable to use as we all know the Hydraulic ones creep back in which will mean the valves wont be moving as much as if the engine were running! |
#31 | |
Quote:
CR wil be about 8.5:1
__________________
#32 |
Well, went to the ford today,
They said the st170 was the same as the other 2 liter engines and only the RS was different. Ordered the RS one and we'll see how it goes Thanks for all the replies.
__________________
#33 |
Colossal Pervert
As I said in my reply to your PM, the RS is 3 layer (as is the normal 2L) and the ST170 is 4 layer..
Part Numbers 2L/RS = 1105772 ST170 = 1071744 I think your parts dept. needs a kick up the arse!
__________________
#34 | |
Quote:
well... wil let them have a look at the numbers.. thanks...
__________________
#35 |
Wye Valley Hardcore
__________________
![]() "BRAVERY IS THE CAPACITY TO PERFORM PROPERLY EVEN WHEN SCARED HALF TO DEATH"
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Headgasket for Zetec 1.8 16V?? | YBJ | Technical help Q & A | 0 | 29-04-2007 04:37 PM |
| Zetec headgasket | JesseT | General Car Related Discussion. | 9 | 02-10-2006 08:59 AM |
| Zetec Turbo headgasket S3 metal jobbie too thin? | XRT_si | General Car Related Discussion. | 0 | 06-09-2006 10:47 PM |
| Zetec Headgasket. | Muzz | General Car Related Discussion. | 4 | 17-07-2006 10:23 PM |
| WILL A FOCUS RS HEADGASKET FIT A STD 2.0L ZETEC??? | Fudgey | General Car Related Discussion. | 23 | 25-01-2005 08:28 AM |
