escort rs turbo fuel pump fit xr3i efi?
Old 11-07-2008, 07:02 PM
TuRbO-CaB-LaD
TuRbO-CaB-LaD's Avatar
Default escort rs turbo fuel pump fit xr3i efi?
escort rs turbo fuel pump fit a xr3i efi? or are they diffrent, cheeRs
Old 11-07-2008, 07:23 PM
mercury grey minter
mercury grey minter's Avatar
No they are different.RS TURBO one's fit at the back of the tank,the XR3i EFI one's fit inside the tank.
Old 11-07-2008, 08:30 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
unless its MFI XR3i then an MFI RST fuel pump will fit, but the RST pump is higher pressure than the XR3i job.
Old 11-07-2008, 08:34 PM
Ade
Fast Ford snapper
Ade's Avatar
All MFI pumps run at th esame pressure IIRC, which is also approx 2 BAR higher than the typical EFi
Also I've never seen a MK4 Escort run an in yank pump.... couldn't even source one in the books when recently scouring all tank options for an injection conversion.
Old 11-07-2008, 09:46 PM
vroooom ptssssh
It Wasnt Me!
Ade, im 99% sure RST pumps are higher pressure than the 3i items!
Old 11-07-2008, 11:27 PM
Ade
Fast Ford snapper
Ade's Avatar
I've seen a few aftermarket listings with all MFi running the same pump, CVH and Cologne, wouldn't suprise me if that was teh case from day one.
Old 12-07-2008, 04:14 PM
vroooom ptssssh
It Wasnt Me!
Hmm, I still believe it is a higher pressure than the 3i job, the sierra cosworth is a higher pressure again from the RST pump but looks the same as all 3 !
Old 12-07-2008, 05:24 PM
fonfe
fonfe's Avatar
fuel pump on efi cabs only run 1 bar of static presure you need 5 bar of static pressure for a rst according to the cabby owners club
Old 16-11-2014, 08:20 PM
Cals_cossie
Cals_cossie's Avatar
I have a cabby running an rs turbo efi conversion, serious over fuelling going on, do you think I wld need an efi tank and pump? Cheers cal
Old 16-11-2014, 08:53 PM
Craigsteen rs
Craigsteen rs's Avatar
Mine is over fuel too been told it down to the chip been taking out before I got it am running a efi turbo in my cabby
90_spec (17-05-2016)
Rs_Motion
Escort MK 5 / MK 6
43
27-12-2018 11:49 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
kosienutter
31
22-08-2015 09:55 AM
dlwarrior
05-08-2015 10:19 AM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: escort rs turbo fuel pump fit xr3i efi?
