| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#1 | ||||
The posh are up!!!
#2 |
Bodybuilding
Trader Score: (0)
Location: Cannot be identified by the information given.
Rep Power: 8 ![]() |
upto 300 bhp with a 5th injector real east to fit
#3 |
also always wondered this also,where does it go into th metering head ?
#4 |
ask cosworth_cab for details his brother done it on his uprated escort rs turbo s2
#5 |
how much do they go for?
#6 |
Bodybuilding
Trader Score: (0)
#7 |
The posh are up!!!
i think it goes into the charge carrier and in the cold start valve?
#8 |
Charge carrier as above
__________________
#9 |
on the air flow meter where the cold start valve is connected, that is removed and the fifth injector fuel suply comes from there. also on the side there is a spare nut which the cold start valve is relocated to. this is how mine is i can take some pics if you want but wont be for a few days as im not going up my unit.
__________________
Ford cars and trucks - Powered by the past - Improved for the future |
#10 |
Trader Score: (1)
Rep Power: 10 ![]() |
i mate this picute might make it abit easier long pipe goes to charge carrier short pipe with bango cold start & short pipe with nut on to metering head
__________________
![]() derbyshire rsoc meeting every 2nd sunday of the month at the paddock mansfield rd derby PS3 GAME TAG-cressys1 wanted meaningfull one night stand
#11 |
I recognise that photo ?
__________________
![]() 395 bhp & 410 lb/ft |
#12 |
The posh are up!!!
will it make i difference to my rs im running around 200 brake mark.
#13 |
I had that made, it atchualy goes off the outlet on the fuel filter then to metering head and then feed to injector on charge pipe. That way you keep the cold start valve as mine was an arsehole starting without it.
__________________
#14 |
Makes no power, its just to stop det. Its not the best method out there as the fuel is not distributed to each cylinder evenly. If looking for big power, go efi and change management. But it worked on my car and I ran 25psi but its horses for courses, it boils down to money and what you can afford.
__________________
#15 |
hey bad boy rs where you been nigger aint seen ya for time???
#16 |
got one of these on my n/a 2.1 it has made a difference, but only becasue my mfi couldnt handle the amount of fuel it needed at higher revs! plus stops your engine burning out if its fueling wrong, think i should have about 5-6 bhp more, but thats just because i got the fuelin sorted! cost me 225 fitted.
#17 | |
Quote:
please someone help cheers guys |
#18 | |||
Balls Deep!
Quote:
Quote:
Quote:
The average metering units fuelling capacity tops out at around the 200bhp mark (some will do more and others less!) so to run more boost and as a result make more power you need to give it more fuel, this is why you fit a 5th injector. It is generally fitted into the CC pipe and injects directly into your charge air as it passes (as in the photo above) and as a result DOES fuel all 4 cylinders evenly. Your tuner will map it to your boost via a controller which will allow your fuel pressure to be turned down a bit (giving you better off boost economy and drivability) but still maintain the correct fuelling when under load! IMO if wanting more power on MFi it's the only way forward! ![]() You can use pretty much use any injector but will need the controller to run it. I have one if you need it, brand new never been fitted still in it's box with instructions PM me if interested.
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk Last edited by Karlos G; 30-01-2009 at 03:52 PM. |
#19 |
![]() BANNED |
karlos g ,why you not running the fifth injector??
#20 |
Balls Deep!
Because i'm building an all steel CVH over the coming months, going EFi (probably megasquirt) and so am leaving my current engine as it is
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk |
#21 |
MF2's rock. You can get really nice driveablility and economy from Mfi with them on. I fit them to sub 200cars if the customer can get one one as you can cruise at 15:1.
__________________
Bespoke calibration and remapping, OEM & Aftermarket management
#22 |
Balls Deep!
__________________
#23 |
#24 |
Balls Deep!
From what i here it's eay to install and a lot of tuners are familiar with it for mapping.
__________________
#25 |
YES I KNOW I CANT SPELL
__________________
" im special,, excuse my spellings" |
#26 |
__________________
#27 |
__________________
#28 |
Balls Deep!
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Breather systems: How easy are they to fit? | boXXer | General Car Related Discussion. | 23 | 27-05-2006 07:59 PM |
| HOW EASY TO FIT | MAD EVO 4 | General Car Related Discussion. | 0 | 23-02-2006 09:44 PM |
| Are they easy to fit | DavesRsTurbo | Ford Escort RS Turbo | 5 | 23-11-2005 10:24 PM |
| launch control easy to fit??????? | rsboy82 | General Car Related Discussion. | 14 | 23-11-2005 11:11 AM |
| how easy is it to fit a ......... | cossywal | Technical help Q & A | 0 | 06-10-2005 12:53 PM |
