| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#201 | ||||
#202 |
Balls Deep!
Only probs I can think of with this idea is that you'll have a really really heavy clutch because firstly the AP clutches have uprated pressure plates and are much heavier than a stock clutch, and secondly your going to have less leverage by shortening the arm therby increasing the amount of force needed at the pedal, this also puts a lot more strain on the cable and quadrant. This is also assuming that there is enough self ajustment at the quadrant to take up the slack created by the arm being closer to the cable, if not your in the same situation as if you'd done nothing but just with a heavier clutch!
JesseT, Did yours disengage properly, and what clutch where you using?
__________________
Zetec Turbo build in progress... For Party DJ's in Suffolk & Essex and AV installs I recommend www.frenzyentertainmentservices.co.uk |
#203 | ||
Quote:
Quote:
Think again about a bicycle. When changing to a larger diameter gear on the front (in our Escort the quadrant) you will need more force but go faster. When changing to a smaller diameter gear at the rear (in our Escort the release arm) exactly the same will happen. So if I calculate how much shorter the release arm should be to gain the same travel as with the larger diameter quadrant then all should be fine. The clutch will release okay and the pedal won't be to "hard"! ![]() The calculation could be made with the simple formula which we all learned at school: D1 x n1 = D2 x n2
__________________
![]() Some Ways To Maintain A Healthy Level Of Insanity:
#204 |
Right finally, we have some quadrants machined up and ready to buy if any of you are interested.
They are £40 each including postage in the UK, the bushes for the first few will be alloybronze, because the delivery for the Iglidur self lubing bushes are months away. You can contact my mate who makes them, directly by email extremesportsproducts@hotmail.com or buy it now from webpage www.extremesportsproducts.com which will be active by the end of day (13/04/08)
__________________
''Mary had a little lamb, she tied it to a pylon...10,000 volts went up its a*se & turned its wool to nylon'' Last edited by nigel b; 16-04-2008 at 09:35 PM. |
#205 |
Wow great!
If they are produced at this point then I would like one instead of trying out my idea. What is postage to The Netherlands going to cost? I'll be looking out for it on the mentioned website!
__________________
#206 | |
Tried to order it but I encounter the following error:
Quote:
__________________
#207 |
Ordered and paid for. Woop woop.
#208 |
is half man, half amazin'
cool i get payed thursday will get mine then!
#209 |
Karlos, I just made it equally short than a mk3 escort would have it as standard. I just had to do the mod because I had a hybrid gearbox with mk3 right half and mk4 left half. Sure the strain and force needed is more, but only some 15% or so. Can't really feel the difference.
#210 |
Ordered!
Can't wait.......
__________________
#211 |
i think about 4 are made on the first side
should be starting to do the second side tonight or tommorow ive edited the web address as i moved the store to the root directory
__________________
''Mary had a little lamb, she tied it to a pylon...10,000 volts went up its a*se & turned its wool to nylon'' |
#212 |
ordered mine the other day!
must be one of the most popular threads i ever started even if it wasnt me that got them made in the end ![]() big up to nigel b for doing them though!
__________________
![]() 188bhp & 200lb/ft |
#213 |
Got my one today!
__________________
#214 |
Think mine is at the postoffice ready for collection. Now comes the tricky bit of crawling under the dash!!
Cheers Nigel |
#215 |
the fitting is the fun part
hopefully should have a guide up asap if anyone gets a bit stuck
__________________
#216 |
most of us have changed the quadrants about 2/3 times now so should be straight forward lol
__________________
#217 |
Got mine today too!!!!!!!!!! Looks the dogs!!
If only I can find that glass hammer to fit the thing!?!?!?!?!? |
#218 |
If someone wants to take a few pics while there on I'd be grateful. Never done one before.
#219 |
I've fitted it last tuesday and drove the car on wednesday. Finally I can cruise around with confidence.....
Big up for Nigel B for making these quadrants. He saved the day!!! For R6Franky, it's not easy to take pictures when fitted because it's a horrible place to get a camera in. Just crawl under your dash and have a good look. It's not hard, just a pain to do because of the tight space your working in. But you should be okay....
__________________
#220 |
R6Franky
i have got some pictures taken before i went away ill see where they are in the next few days for you
__________________
#221 |
Champion Clit Licker !!!
PM nigel
dave
__________________
![]() PSN ID: SPINAL_CHORD |
#222 |
is it still possible to buy a metal quadrant ??
thanks |
#223 |
yes it is
ill find out this afternoon if there is any made
__________________
#224 |
2nd that, i meant to get one ages ago and totally slipped my mind! Pm me when you know nigel,
Cheers, Dave.
__________________
![]() RS Turbo being broken......Focus RS now here!!! |
#225 |
all the quadrants that got made last time have all gone(over 25 i think)
it will take at least a week for material and bushes to turn up then were away snowboarding realistically looking at 1 month away
__________________
#226 |
Oh right, let us know when they're ready mate!
__________________
#227 |
Hi
Any update on those quadrants ? I would like to buy one for my S2 Henrik
__________________
Rebuilding a RS Turbo is not hard... Its an expensive lifestyle....... S2 JamSport 1.9 CVH, UltraLite Atec, still working on getting it MOT |
#228 |
are these quadrants still available ive just been on the website and says there out of stock i really desperatley need one by next weekend so if anyone can help me i wud greatly apreciate it
#229 | |
Quote:
my mate has gone away for 2 weeks,thats why it says none in stock i think there is about 13 left i might have an alternative idea if your really stuck,ill have a look in a bit
__________________
#230 |
wats your other idea 4 now defo want one wen he gets back cheers mate
#231 |
what i was thinking was you buy mine for the same price and ill get one later if you desperately need it
__________________
#232 |
maybe a good idea ill check the bank tmara make sure ive got the money for certain b4 i say yes i am quite desperate tho clutch is slipping really badly i need to get the paddle one on asap cheers mate ill let u no tmara
#233 |
Time to play The Game HHH
I got mine
#234 |
#235 | |
Quote:
#236 |
Will this fit on my Fiesta XR2 as well im after getting the AP CP2000-8 clutch.
Do you just need this metal quadrant and the mk5 clutch arm? |
#237 | |
Quote:
How much does it cost me to buy one and ship it to me in Malta please? |
#238 |
Trader Score: (0)
Rep Power: 3 ![]() |
are you still getting hold of these ??
__________________
#239 |
| Display Modes | |
