car wont turn on
car wont turn on
Hi, my car dosnt start after i boot it. i have to wait like half an hour to turn it back on agen. Is this the starter motor playing up. Ive even got a heat shield. Im getting tired of push starting the car.
You get a Starter Heat Shield from burton power which costs about Ł35, but it does the starter a hell of alot good, also consider wrapping Exhaust wrap around you turbo manifold which will also stop the heat generating around the starter and also the engine by 70%
probably the bronze bush at the front of the starter is poked causing the rotor to touch the stator , easy enough to replace
i have not had problems with my turbo for 6 years now , but i did use 3m worth of heat bandage around the downpipe
The Underdog
29
07-09-2015 09:49 PM
CabrioTurbo
01-08-2015 11:04 AM
