| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Ford Escort RS Turbo This forum is for discussion of all things pertaining to the Ford Escort Rs Turbo Series 1 and 2. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#161 | ||||
__________________
![]() 186bhp with 205ft at 15psi Italy World Cup Winners 34* 38* 82* 06* Last edited by makaveli96; 16-11-2009 at 10:35 PM. |
#162 | |
Quote:
good setup! all you need now is a bigger master cylinder. |
#163 |
Tuuurbo
#164 |
Are the calipers of a Ford Scorpio Cosworth the same as the sierra 4x4 for the front of a ERST?
__________________
" Dream as if you live forever, live as if you die today. " ![]() Check my project on http://passionford.com/forum/restorations-rebuilds-and-projects/207111-big-s2-rs-turbo-project-finished-lots-of-pics.html |
#165 |
competant bodger
will the 2wd 4 pots fit with standard wheels?
#166 |
Trader Score: (0)
Rep Power: 7 ![]() |
Ive finally got round to getting my cossie 4 pots on my estate this weekend ive not tried them out yet because the cars not on the road yet but they look so much better.
Firstly i got my calipers off b19 cvh off here (cheers pal) with the right hoses to fit straight onto my car. After reading up on the conversion i got a friend to machine the required 4mm off the mounting face so they looked like this ![]() ![]() after getting the discs from a local motor factors i offered everything up and the disc sat smack bang in the middle of the caliper so let the drilling comence. The standard calipers use an m10 mounting bolt where as the cosworth stuff uses m12 so i drilled the hubs out and tapped them m12 ![]() now the mounting holes in the hubs are slightly out of line to the holes in the calipers so i opened the holes out in the calipers from 12mm to 13mm and this gave me plenty of room to line them up and get the bolts in. Now with the calipers all bolted up ![]() dont they just look so much better that the standard jobbies and even better still my wheels still go over them so i dont have to change to alloys ![]() hope this helps some one out if there planing on doing the same thing once ive got the car on the road ill do a little update on how they perform cheers for reading mark.
__________________
![]() Check out my xr3i Re-build here http://passionford.com/forum/restora...e-rebuild.html Last edited by xrmalin; 03-03-2010 at 07:09 PM. |
#167 |
hy i have front 4x4 calipers and 4x4 discs i need to put 20.2 mm spacer between the bolt and i c an t fit the standard 15 rs trubo wheels on i need to buy me 2wd discs an fix it with 1mm spacer that i can again put my 15 standard rs turbo wheels on
#168 |
im thinking fiting 2.0 ltr focus rear brakes on rs turbo my friend doing ,pretty sure i can make them fit mabe rs 2000 cable will fit 2 i hope
__________________
loysport http://www.bafabrications.co.uk/ PM MONSTER FOR CUSTOM VIN TAGS carpartsexpress mail order ford parts 01914272186 |
#169 |
boost junkie.....
im about to do the cossie rear brake conversion on my s1. already got cross grooved + drilled front disks. will let you know how it went in about a weeks time....hopefully....
#170 |
years ago rear wheel drive fords had nuts and front wheel drive had bolts. i think this was just way they did things
#171 |
Can't get my pads to fit for some reason, Also, but I thought I was grinding on the caliper bracket but finding it hard for them to spin freely.
scrap car Last edited by kristinthomas21; 04-02-2011 at 09:47 AM. Reason: New Problem |
#172 | |
It's ALIVE..Well sort of!
Sorry if I have missed the answer to my question, but had a quick look and didn't see anything apart from:
Quote:
quote] But my question is can I change my master cylinder (with or without changing servo) to a cosworth one and get away with having more fluid pushed through to help with stopping power on a standard brake set up? Now baring in mind I have a converted Cabriolet with as far as I know standard brakes. btw, a great thread peeps
#173 |
Is there anyone that knows the ford number to order a handbrakecable for the rear brakes with discs?
Thanks in forward
__________________
" Dream as if you live forever, live as if you die today. " ![]() Check my project on http://passionford.com/forum/showthread.php?t=207111 |
#174 |
hey ppl im having some trouble trying to find the right handbrake cable. My cars a S1 RS Turbo and im trying to put cossie 4x4 calipers and disc's on the back but ive try'd the rs2000 cable but the sleeving is to short so i tryd a cossie one but it look like its exactly the same but with a longer inner cable. plz help. thanks!!!
#175 |
i did this conversion using everything you said about 12months ago and the wheel wouldnt go round i had 2 get my 283 disc machined down 2 278 the same size as a 4x4 disc.....then they worked fine....has any1 come across with this problem
#176 | |
Quote:
#177 | |
Quote:
Lee
#178 |
Is the BC2290 from burton the right handbrake cable to order for this conversion?
https://www.burtonpower.com/product_...px?CCode=PC090
__________________
#179 | |
rs turbo from Greece...
Quote:
#180 |
if you call burtons and say your doing the rs turbo rear disc conversion they will give you the right handbrake cable coz thats what i did after trying about 4 different cables
#181 |
Hi there i just read through the top of your step by step on the rear conversion do I still need to connect my brake compensators back up (load sensors) or do I leave em off any help please?
#182 |
Leave them fitted, make sure they are working.
Unless you are fitting the inline type or a bias valve.
__________________
Megasquirt project underway, hope my clutch can stand 20psi of boost ![]()
#183 |
They came off me e reg series two they bolt onto the wishbones what's that type sorry all new to this if I don't know I ask lol I also got cossie brakes on the front running a twenty five master cylinder is that cylinder ok aswell cheeRS
#184 |
What hand brake cable do u use for the front part, the one that goes from the lever to the join?
#185 |
right prob i am having is pedal is crap, cossie brakes all round and i have fitted mk5 servo and new master cyl (25.4), with restrictors then to rs turbo restrictors for the rear but rear brakes still lock up rapid. Do i have to remove both restrictors n fit bias valves instead for this set up to work right?? my lines r set up FR+RL And FL+RR off the master cyl. what has every1 else done? cheers
#186 |
hi ive done this conversion and now for some reason my tires have started to rub on my arches?? does anyone else have this problem?
#187 | |
Quote:
Lee
#188 |
Does my standard front brake line fit to cosworth 4x4 front caliber directly?
__________________
S2 RST 1989 LHD / http://s2rst.blogspot.com/ |
#189 |
If I already have braided hoses for the escort calipers...will theese fit the cossie brakes?
#190 |
#191 |
YOREVOL
just a quick note, when fitting 2wd calipers fit the hose to the inner bleed nipple hole, and the nipple to the hose hole. you wont need the 90 degree uion to avoid the cv joint.
i did it this way but loads of clearance issues so going to use bmw brembos and focus discs. btw what are a pair of 2wd callipers machined to fit rst worth? |
#192 |
I think you really cant do this conversion right.
I have now 4x4 front calibers, 2wd discs. In rear 4x4 cosworth full brakes and wilwood bias valve between rear brake line. Still rear brakes lock first and front brakes are horrible and dont have power. Next option will be different master cylinder or selling this car, this is now 3rd summer fighting with brakes.
__________________
S2 RST 1989 LHD / http://s2rst.blogspot.com/ Last edited by Antti O; 09-07-2011 at 05:58 PM. |
#193 | |
I've done this conversion again over the weekend so I've now updated it a little and added the part number for the correct handbrake cable!
First Line Parts FKB1340 for Ford Escort 92>95 with rear disks excluding 4x4. Also this time I countersunk the rear caliper adaptors and used countersunk bolts, much neater! Quote:
I've done this conversion again, this time on an XR3i (Non ABS with the 4 output master cylinder) and without a bias valve. They work fantastically now, better than they did on the RST. No lock ups and breaks evenly as it should. Handbrake holds well too. What M/C are you using? Lee
#194 |
Just a quick update to add info about the Goodridge Banjo bolts supplied with the rear hose kit. They were too long and leaked. I had to shorten them by about 2mm to stop them bottoming out.
Lee
#195 |
Has anyone tried fit a Volvo 240 calipers? The are 4 pot and lot cheaper then "cosworth" ones. Fitted on mk1 Escorts as upgrade.
#196 |
hi guys, little confused after reading the whole thread, quick question will the set up below work on my s2
front setup 2 cosworth 2wd calipers 2 cosworth new discs ( not sure if the 4x4 or 2wd)? set of ds2500 pads What price would ya put on it? cheers Simon |
#197 |
Trader Score: (0)
I used 2wd disc's with 2wd calipers when i did the the conversion on my old mk4 estate. Price is hard to say depending on where you get everything from
__________________
![]() Check out my xr3i Re-build here http://passionford.com/forum/restora...e-rebuild.html |
#198 |
i know some1 has asked the question about the master cyclinder, and some says it fine but i was thinkin how can it be fine?
as the pressure from the cosworth system will be much great than the rs turbo system, so if your not changing the master cyclinder your not getting the full use of the cosworth brakes? i dont know if im right or not, i just want to know as im planning to convert my braking system, so just want to know as i want to buy all the parts once also is there a difference in changing 2 or 4 pots or isit the same? also the pictures shown are they of 4 or 2 pot brakes? and finally do 4 pots fit under standard rs turbo alloys? |
#199 |
yes they fit under the std alloys^
st170 disc and mk3 mondeo caliper is also a good setup, should be cheaper to. |
#200 |
v6 mondeo calipers???
also is that just for the front?????? as i want to do front and back also whats about the master cyclinder? |
| Display Modes | |
